  1. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    16,830
Page 74 of 135 FirstFirst ... 2464697071727374757677787984124 ... LastLast
Threads 2191 to 2220 of 4022
Forum: Help and Discussion
  1. Oscilloscope screen shots of Actia XS Evolution Interface !
    Started by titoun, 27th March, 2015 12:23 PM
    27th March, 2015, 12:23 PM Go to last post
  2. i need a usb connect cable for a old ford ids vcm tool
    Started by sideshow, 19th March, 2015 10:45 PM
    23rd March, 2015, 07:11 PM Go to last post
  3. bmw e90 2008 ecu swap
    Started by garagetech, 6th February, 2015 12:57 AM
    22nd March, 2015, 09:37 PM Go to last post
  4. renault explorer ?
    Started by electrohicham, 9th December, 2014 02:58 PM
    22nd March, 2015, 04:33 AM Go to last post
  5. UPA programmer from elrasoft with accessories
    Started by hamzadaw2000, 18th March, 2015 06:03 AM
    21st March, 2015, 03:38 PM Go to last post
  6. Vcm rotanda faulty
    Started by garagetech, 20th March, 2015 12:35 PM
    20th March, 2015, 12:44 PM Go to last post
  7. Launch X431 change the serial number in the Smartbox
    Started by Dacha, 16th February, 2015 02:52 AM
    18th March, 2015, 05:27 PM Go to last post
  8. Lounch X431 not connected after cracked soft
    Started by BySimlockcu, 19th April, 2011 02:30 PM
    16th March, 2015, 10:25 AM Go to last post
  9. Edit/correct w204/w212/w207 assyst with xentry
    Started by smuggler86, 13th March, 2015 02:24 PM
    14th March, 2015, 10:19 PM Go to last post
    12th March, 2015, 09:55 AM Go to last post
  10. JLR SDD V138 updates
    Started by cbp, 12th March, 2015 01:30 AM
    12th March, 2015, 01:30 AM Go to last post
  11. Labtool eprom programmer parallel cable
    Started by ecufix, 11th March, 2015 06:57 PM
    11th March, 2015, 08:55 PM Go to last post
  12. gold 2 board AUTOCOM Firmware needed
    Started by paul_12345, 20th January, 2014 11:11 PM
    10th March, 2015, 11:07 PM Go to last post
  13. Mercedes initial startups of replaced control units
    Started by smuggler86, 28th February, 2015 08:26 PM
    9th March, 2015, 08:51 AM Go to last post
  14. MITSUBISHI MUT III ERROR
    Started by cbp, 9th March, 2015 05:35 AM
    9th March, 2015, 05:35 AM Go to last post
  15. UPA USB 1.3 PROBLEM
    Started by kospoz, 6th March, 2015 08:23 PM
    7th March, 2015, 09:08 AM Go to last post
  16. fvdi commander
    Started by lellocchio, 1st March, 2015 10:51 PM
    5th March, 2015, 11:22 AM Go to last post
  17. Peugeot Planet Interface Repair solutions !
    Started by titoun, 3rd March, 2015 11:44 AM
    4th March, 2015, 10:25 AM Go to last post
  18. Advice on Tango programmers for sale in China
    Started by ruwi, 2nd March, 2015 06:36 PM
    2nd March, 2015, 08:32 PM Go to last post
  19. Help with update delphi 2013.3 to 2014.2
    Started by kospoz, 1st March, 2015 09:00 PM
    2nd March, 2015, 08:07 AM Go to last post
  20. ford vcm clone burn resistor on usb cord
    Started by sideshow, 1st February, 2015 02:26 AM
    1st March, 2015, 10:37 PM Go to last post
  21. Looking for R270 repair solution
    Started by Diagnoster, 8th January, 2015 12:47 PM
    1st March, 2015, 05:06 PM Go to last post
  22. GQ-4x prog
    Started by Phrozen, 25th February, 2015 10:36 PM
    1st March, 2015, 12:58 AM Go to last post
  23. where is best place to get good quality tech2 mainboards
    Started by sideshow, 24th February, 2015 01:39 PM
    24th February, 2015, 01:39 PM Go to last post
  24. Xentry DAS Offline Coding Problem HELP !!!!
    Started by bersch8688, 17th March, 2014 02:21 PM
    16th February, 2015, 12:42 PM Go to last post
  25. Need Help
    Started by hcsaibot, 12th February, 2015 07:09 PM
    14th February, 2015, 11:45 PM Go to last post
  26. Judit box Adapter kabel 50381374
    Started by Kolcocnc, 10th February, 2015 11:02 PM
    10th February, 2015, 11:02 PM Go to last post
  27. Unhappy Tacho universal 2008 keyboard problem
    Started by piedone82, 23rd August, 2013 11:23 PM
    6th February, 2015, 07:51 PM Go to last post
  28. help pin code 2012 dacia sandero 95040 uch
    Started by ISABINO, 23rd April, 2013 12:37 AM
    6th February, 2015, 07:49 PM Go to last post
  29. Compact 3 MUX used with xpress card-to-com
    Started by ACDC, 13th January, 2015 05:45 PM
    4th February, 2015, 04:39 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
