  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    14,193
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    13,511
Page 2 of 41 FirstFirst 123456712 ... LastLast
Threads 31 to 60 of 1230
Forum: Help and Discussion
  1. Eaton Service Ranger 3.2
    Started by gwdsike, 16th October, 2023 03:04 AM
    16th October, 2023, 03:04 AM Go to last post
  2. FLS file from hydraulic ecu CAT 277B to bin
    Started by milzal, 13th October, 2023 10:06 AM
    13th October, 2023, 10:06 AM Go to last post
  3. EMR1 Deutz ecu file needed.
    Started by dany_l2003, 7th October, 2023 11:33 AM
    7th October, 2023, 11:33 AM Go to last post
  4. Massey Ferguson MF40 Working time
    Started by brylant2311, 7th June, 2022 06:14 PM
    29th September, 2023, 01:02 AM Go to last post
  5. Opinions about Alfa Romeo Giulietta!
    Started by BulyEZ, 5th February, 2023 08:11 PM
    29th September, 2023, 12:48 AM Go to last post
  6. AUDI A3 1.9 TDI ASZ Turbo problem
    Started by dawco998, 20th July, 2023 04:24 PM
    29th September, 2023, 12:34 AM Go to last post
  7. JCB Fastrac 3230 dashboard flash + eeprom
    Started by anawfulhoore, 28th September, 2023 07:00 PM
    28th September, 2023, 07:00 PM Go to last post
  8. W205 OM651 C220 DPF PROBLEM
    Started by n00bforever, 2nd September, 2023 02:12 AM
    w205 dpf diesel
    25th September, 2023, 08:40 AM Go to last post
  9. Volvo ECU issue
    Started by millicent, 25th September, 2023 01:20 AM
    25th September, 2023, 01:20 AM Go to last post
    19th September, 2023, 07:31 AM Go to last post
  10. Ford Ranger 3,0 tdi
    Started by thunder2, 31st August, 2023 05:30 PM
    18th September, 2023, 02:21 AM Go to last post
  11. Sprinter FSCU pressure sensor problem
    Started by mihaiti, 6th September, 2023 02:31 PM
    6th September, 2023, 02:31 PM Go to last post
  12. 2002 boxer camper van wont rev
    Started by coder5, 1st September, 2023 03:51 PM
    1st September, 2023, 03:51 PM Go to last post
  13. 04024 Temic PLD in Citaro bus
    Started by fokker2003, 23rd June, 2023 11:23 AM
    30th August, 2023, 06:58 PM Go to last post
  14. volvo fh 2017 plase help
    Started by myrat, 30th August, 2023 07:43 AM
    30th August, 2023, 07:43 AM Go to last post
  15. Porsche Cayenne 2014 headlights coding
    Started by szabelek22, 24th August, 2023 01:01 PM
    24th August, 2023, 01:01 PM Go to last post
  16. Special Instruction REHS0540
    Started by tedy765, 10th January, 2011 01:29 PM
    10th August, 2023, 12:07 AM Go to last post
  17. Looking for Fendias Update Tool
    Started by FlyJet, 7th August, 2023 08:07 AM
    7th August, 2023, 08:07 AM Go to last post
  18. Cummins N14 Original Dump
    Started by elecautocr, 7th May, 2010 11:22 PM
    5th August, 2023, 04:51 PM Go to last post
    29th July, 2023, 10:26 PM Go to last post
  19. Linde pathfinder BT canbox not working
    Started by dellboymark, 27th July, 2023 11:27 PM
    27th July, 2023, 11:27 PM Go to last post
  20. citroen c3 2019 yaw rate sensor location
    Started by delltrotter, 12th July, 2023 09:37 AM
    18th July, 2023, 09:29 PM Go to last post
  21. Hantek 3064A VII
    Started by thunder2, 16th July, 2023 12:11 PM
    16th July, 2023, 12:11 PM Go to last post
  22. fault code erase in DQ200 DSG 7
    Started by eLoP, 19th June, 2023 04:16 PM
    14th July, 2023, 02:39 PM Go to last post
  23. CM850 CUMMINS bench
    Started by alclot, 12th July, 2023 12:13 PM
    12th July, 2023, 12:13 PM Go to last post
  24. DDEC III - Missing meta file for my software version
    Started by notAhoser, 10th July, 2023 12:13 PM
    ddec
    10th July, 2023, 12:13 PM Go to last post
  25. Minin R56 N47 Twin Pin plug
    Started by djorgensen, 19th June, 2023 04:48 PM
    19th June, 2023, 04:55 PM Go to last post
  26. mercedes c200 coolant fan running all the time.
    Started by coder5, 15th June, 2023 05:08 PM
    18th June, 2023, 07:32 PM Go to last post
  27. DDEC 60 Series Flash Files Needed
    Started by SaMirakle, 25th January, 2011 01:42 PM
    1st June, 2023, 05:49 AM Go to last post
    29th May, 2023, 01:54 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
