  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    15,808
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    15,072
Page 1 of 294 1234561151101 ... LastLast
Threads 1 to 30 of 8807
Forum: Help and Discussion
  1.   Sticky Threads
  2. Sticky Thread Sticky: How to repair ABS system and units thread (repair,help,questions)
    Started by soxten, 25th July, 2014 06:22 AM
    21 Pages
    1 2 3 ... 21
    13th January, 2024, 11:30 AM Go to last post
  3. Sticky Thread Sticky: >>>>>>>>>>>>>>>>>>>>>>>>> AUTODATA <<<<<<<<<<<<<<<<<<<<<<<<<
    Started by PremierD, 30th December, 2010 08:14 PM
    30th December, 2010, 08:14 PM Go to last post
  4.   Normal Threads
  1. ABS-ESP Long Code Calculator Helper v2 English
    Started by rob h, 23rd November, 2014 02:07 PM
    9 Pages
    1 2 3 ... 9
    Today, 10:30 AM Go to last post
  2. MERCEDES ML500 GLOW PLUG CONTROL MODULE WIRING
    Started by bangreno, 17th May, 2024 12:00 PM
    17th May, 2024, 12:00 PM Go to last post
  3. Activation ESI Tronic 2013
    Started by ETMS, 16th May, 2024 03:23 PM
    16th May, 2024, 03:23 PM Go to last post
  4. Lost 5N0614517N abs module coding in Tiguan 2009
    Started by acam712, 7th August, 2017 03:52 PM
    15th May, 2024, 03:46 PM Go to last post
  5. Red face E46 Light module EPROM
    Started by Bryan, 13th May, 2024 09:53 PM
    13th May, 2024, 09:53 PM Go to last post
  6. Com 2003 citroen repair
    Started by PSAcars, 25th February, 2017 05:10 PM
    13th May, 2024, 09:13 PM Go to last post
  7. BMW X1 F48 Rear signals usa to eu
    Started by ostrowpawelprac, 13th May, 2024 02:49 PM
    13th May, 2024, 02:49 PM Go to last post
  8. UPA USB Activation key
    Started by ChaunBoon, 13th May, 2024 02:00 PM
    13th May, 2024, 02:00 PM Go to last post
  9. Help with Telecharge (Diagbox clone Full Chip)
    Started by ljamert, 13th May, 2024 05:25 AM
    13th May, 2024, 06:24 AM Go to last post
  10. Gearbox DQ500 Continental please help
    Started by adiwob, 12th May, 2024 10:22 PM
    12th May, 2024, 10:22 PM Go to last post
  11. peugeot boxer wiring please
    Started by BoNzOtM, 12th May, 2024 08:46 PM
    12th May, 2024, 08:46 PM Go to last post
  12. Techstream activation Key
    Started by CarCity, 14th January, 2018 07:31 AM
    27 Pages
    1 2 3 ... 27
    12th May, 2024, 08:30 PM Go to last post
  13. NEED PINOUT ABS RENAULT CLIO 4 OR CAPTUR
    Started by newgeniehex, 10th May, 2024 07:06 PM
    11th May, 2024, 08:31 PM Go to last post
  14. e39 LCM IIIB software problem
    Started by DjDecibel, 11th May, 2024 12:51 AM
    11th May, 2024, 03:09 PM Go to last post
  15. Problem ECU Scirocco 2.0 TDi EDC17CP14
    Started by Danimp94, 16th March, 2019 05:27 PM
    11th May, 2024, 10:49 AM Go to last post
  16. Elrasoft UUSP script for secured Motorola 9S12
    Started by tihiuvek, 10th May, 2024 04:39 PM
    11th May, 2024, 06:54 AM Go to last post
  17. MIB STD2 PQ Bootloop
    Started by elc0nd0r, 10th May, 2024 06:15 PM
    10th May, 2024, 06:15 PM Go to last post
  18. Diag tool
    Started by laserkill, 10th May, 2024 05:25 PM
    10th May, 2024, 05:25 PM Go to last post
  19. Good pcf7935??
    Started by ziko, 10th May, 2024 01:56 PM
    10th May, 2024, 01:56 PM Go to last post
  20. a4 b5 help to turn on a/c on standalone ecu
    Started by sebol1204, 10th May, 2024 11:47 AM
    10th May, 2024, 11:47 AM Go to last post
  21. Opel Zafira C BCM configuration
    Started by gogetit, 3rd April, 2024 11:59 AM
    9th May, 2024, 12:16 PM Go to last post
  22. TL866 + soic8 clip read issue
    Started by mancioks, 16th March, 2018 08:03 PM
    3 Pages
    1 2 3
    9th May, 2024, 10:41 AM Go to last post
  23. change vin in e series bmw cluster eeprom file
    Started by neilp1990, 8th May, 2024 11:11 PM
    8th May, 2024, 11:11 PM Go to last post
  24. BMW SZL F30 (3 series) eeprom
    Started by shooperis, 8th May, 2024 02:00 PM
    8th May, 2024, 08:34 PM Go to last post
  25. peugeot boxer 2005 speed limiter
    Started by m300td, 8th May, 2024 11:08 AM
    8th May, 2024, 01:49 PM Go to last post
  26. IVECO DAILY BCM Pinout
    Started by Anass GM, 7th May, 2024 05:04 PM
    8th May, 2024, 12:49 PM Go to last post
  27. 4g0907553f A6 level control
    Started by regeleking, 7th May, 2024 02:54 AM
    7th May, 2024, 09:17 PM Go to last post
  28. Tiguan ABS TRW 450 C2 Coding
    Started by razor1199, 30th November, 2021 07:34 PM
    7th May, 2024, 12:37 PM Go to last post
    7th May, 2024, 12:32 PM Go to last post
  29. Audi A5 2018 us to eu rear light coding
    Started by Marcins70r, 6th May, 2024 07:52 PM
    6th May, 2024, 07:52 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
