  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    12,755
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    12,167
Page 3 of 293 FirstFirst 123456781353103 ... LastLast
Threads 61 to 90 of 8779
Forum: Help and Discussion
  1. Denso Injector Coding - Peugeot Boxer
    Started by dfidalgo, 25th March, 2024 09:31 AM
    denso, injector, peugeot
    26th March, 2024, 08:38 AM Go to last post
  2. Did I fry my ECU?
    Started by tarkanovv, 22nd March, 2024 09:04 PM
    24th March, 2024, 08:08 PM Go to last post
  3. Long Coding - caddy 2019 - front LED DRL lights - blink
    Started by Mooti, 24th March, 2024 09:34 AM
    24th March, 2024, 09:34 AM Go to last post
  4. Range rover sport mileage
    Started by maurineu, 23rd March, 2024 06:01 PM
    23rd March, 2024, 06:01 PM Go to last post
  5. Sharan long encoding
    Started by macmateusz, 23rd March, 2024 03:47 PM
    23rd March, 2024, 03:47 PM Go to last post
  6. Foxflash problem help
    Started by mkom82, 23rd March, 2024 12:16 PM
    23rd March, 2024, 12:16 PM Go to last post
  7. Boxer 2008 Swop BSi
    Started by ITBosssa, 20th March, 2024 04:33 PM
    bcm, bsi, fiat ducato, peugeot bozer
    21st March, 2024, 05:20 PM Go to last post
  8. Looking for a "103 files of EDC16U1" .rar archive
    Started by deliaga, 21st March, 2024 03:34 PM
    21st March, 2024, 03:34 PM Go to last post
  9. chave mercedes nao funciona
    Started by sasa lima, 21st March, 2024 02:46 PM
    21st March, 2024, 02:46 PM Go to last post
  10. Long code help for VW Golf V
    Started by mesterel87, 20th March, 2024 11:20 AM
    21st March, 2024, 11:58 AM Go to last post
  11. VAG 1.5 TSI/TFSI - Take off assist?
    Started by krokies, 19th March, 2024 11:47 PM
    19th March, 2024, 11:47 PM Go to last post
  12. TOSHIBA 1611F1146 PDF
    Started by kaziukas1958, 30th May, 2017 09:42 PM
    19th March, 2024, 09:06 PM Go to last post
    19th March, 2024, 11:47 AM Go to last post
  13. comfort system gone after program immo remotes pls help
    Started by darionapa, 19th March, 2024 08:52 AM
    dashboard
    19th March, 2024, 08:52 AM Go to last post
  14. gateway Renault e-tech 2023.
    Started by fww1, 19th March, 2024 07:56 AM
    19th March, 2024, 07:56 AM Go to last post
  15. Gateway 6R0907530C error
    Started by jolor, 12th May, 2020 06:20 PM
    18th March, 2024, 10:34 PM Go to last post
  16. will vvdi prog virginize peugeot/citroen bsi modules?
    Started by neilp1990, 18th March, 2024 12:11 AM
    18th March, 2024, 12:00 PM Go to last post
  17. xc90ii 2016 cem ecu problem
    Started by brosla7, 17th March, 2024 07:35 PM
    17th March, 2024, 07:35 PM Go to last post
  18. fiat tool
    Started by dzejkoff, 14th March, 2024 10:12 PM
    17th March, 2024, 09:38 AM Go to last post
  19. Toolbox 2.1
    Started by igor7777, 14th March, 2024 06:36 AM
    14th March, 2024, 06:36 AM Go to last post
  20. EDC16 Throttle Sensor/Acceleration pedal linearization map
    Started by empies, 13th March, 2024 02:33 PM
    13th March, 2024, 02:33 PM Go to last post
  21. FORD C-MAX (II) 2012 BCM software fix
    Started by Jus Jus, 13th March, 2024 09:16 AM
    13th March, 2024, 11:49 AM Go to last post
  22. Honda Jazz EGR Off
    Started by gagi08, 13th March, 2024 10:38 AM
    13th March, 2024, 10:38 AM Go to last post
  23. Bentley arnage
    Started by kaamil, 13th March, 2024 04:43 AM
    13th March, 2024, 04:43 AM Go to last post
  24. doblo 1.3mjet start problem
    Started by gccb21, 27th February, 2024 04:59 PM
    12th March, 2024, 07:11 PM Go to last post
  25. W204 climate control
    Started by mffa, 11th February, 2020 11:27 AM
    4 Pages
    1 2 3 ... 4
    12th March, 2024, 01:19 AM Go to last post
  26. BMW CCC E90 repair solution winkfp
    Started by CarDiag84, 15th July, 2016 10:44 AM
    3 Pages
    1 2 3
    10th March, 2024, 06:55 AM Go to last post
  27. long coding vw polo 6R 2010
    Started by galaxy0634, 9th March, 2024 05:00 PM
    9th March, 2024, 05:00 PM Go to last post
  28. Obdstar p50 vs cg70
    Started by fuzz1, 1st July, 2023 11:18 AM
    8th March, 2024, 04:11 PM Go to last post
  29. Launch crp909 blown component
    Started by fuzz1, 3rd June, 2023 11:50 AM
    8th March, 2024, 03:56 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
