  1. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    15,564
Page 1 of 294 1234561151101 ... LastLast
Threads 1 to 30 of 8811
Forum: Help and Discussion
  1.   Sticky Threads
  2. Sticky Thread Sticky: How to repair ABS system and units thread (repair,help,questions)
    Started by soxten, 25th July, 2014 06:22 AM
    21 Pages
    1 2 3 ... 21
    13th January, 2024, 11:30 AM Go to last post
  3. Sticky Thread Sticky: >>>>>>>>>>>>>>>>>>>>>>>>> AUTODATA <<<<<<<<<<<<<<<<<<<<<<<<<
    Started by PremierD, 30th December, 2010 08:14 PM
    30th December, 2010, 08:14 PM Go to last post
  4.   Normal Threads
    Today, 07:16 AM Go to last post
  1. mercedes w220 dash
    Started by pawl, 22nd May, 2024 09:04 PM
    Yesterday, 09:15 PM Go to last post
  2. Reset history/ DTCs PSA SID807evo
    Started by mexanico1971, Yesterday 05:46 PM
    Yesterday, 05:46 PM Go to last post
  3. Red face E46 Light module EPROM
    Started by Bryan, 13th May, 2024 09:53 PM
    Yesterday, 02:49 PM Go to last post
  4. W169 2005 Limp Mode ( ESP )
    Started by stammm, 22nd May, 2024 12:08 PM
    22nd May, 2024, 12:08 PM Go to last post
  5. UPA USB Activation key
    Started by ChaunBoon, 13th May, 2024 02:00 PM
    21st May, 2024, 03:46 PM Go to last post
  6. ABS-ESP Long Code Calculator Helper v2 English
    Started by rob h, 23rd November, 2014 02:07 PM
    9 Pages
    1 2 3 ... 9
    20th May, 2024, 10:30 AM Go to last post
  7. MERCEDES ML500 GLOW PLUG CONTROL MODULE WIRING
    Started by bangreno, 17th May, 2024 12:00 PM
    17th May, 2024, 12:00 PM Go to last post
  8. Activation ESI Tronic 2013
    Started by ETMS, 16th May, 2024 03:23 PM
    16th May, 2024, 03:23 PM Go to last post
  9. Lost 5N0614517N abs module coding in Tiguan 2009
    Started by acam712, 7th August, 2017 03:52 PM
    15th May, 2024, 03:46 PM Go to last post
  10. Com 2003 citroen repair
    Started by PSAcars, 25th February, 2017 05:10 PM
    13th May, 2024, 09:13 PM Go to last post
  11. BMW X1 F48 Rear signals usa to eu
    Started by ostrowpawelprac, 13th May, 2024 02:49 PM
    13th May, 2024, 02:49 PM Go to last post
  12. Help with Telecharge (Diagbox clone Full Chip)
    Started by ljamert, 13th May, 2024 05:25 AM
    13th May, 2024, 06:24 AM Go to last post
  13. Gearbox DQ500 Continental please help
    Started by adiwob, 12th May, 2024 10:22 PM
    12th May, 2024, 10:22 PM Go to last post
  14. peugeot boxer wiring please
    Started by BoNzOtM, 12th May, 2024 08:46 PM
    12th May, 2024, 08:46 PM Go to last post
  15. Techstream activation Key
    Started by CarCity, 14th January, 2018 07:31 AM
    27 Pages
    1 2 3 ... 27
    12th May, 2024, 08:30 PM Go to last post
  16. NEED PINOUT ABS RENAULT CLIO 4 OR CAPTUR
    Started by newgeniehex, 10th May, 2024 07:06 PM
    11th May, 2024, 08:31 PM Go to last post
  17. e39 LCM IIIB software problem
    Started by DjDecibel, 11th May, 2024 12:51 AM
    11th May, 2024, 03:09 PM Go to last post
  18. Problem ECU Scirocco 2.0 TDi EDC17CP14
    Started by Danimp94, 16th March, 2019 05:27 PM
    11th May, 2024, 10:49 AM Go to last post
  19. Elrasoft UUSP script for secured Motorola 9S12
    Started by tihiuvek, 10th May, 2024 04:39 PM
    11th May, 2024, 06:54 AM Go to last post
  20. MIB STD2 PQ Bootloop
    Started by elc0nd0r, 10th May, 2024 06:15 PM
    10th May, 2024, 06:15 PM Go to last post
  21. Diag tool
    Started by laserkill, 10th May, 2024 05:25 PM
    10th May, 2024, 05:25 PM Go to last post
  22. Good pcf7935??
    Started by ziko, 10th May, 2024 01:56 PM
    10th May, 2024, 01:56 PM Go to last post
  23. a4 b5 help to turn on a/c on standalone ecu
    Started by sebol1204, 10th May, 2024 11:47 AM
    10th May, 2024, 11:47 AM Go to last post
  24. Opel Zafira C BCM configuration
    Started by gogetit, 3rd April, 2024 11:59 AM
    9th May, 2024, 12:16 PM Go to last post
  25. TL866 + soic8 clip read issue
    Started by mancioks, 16th March, 2018 08:03 PM
    3 Pages
    1 2 3
    9th May, 2024, 10:41 AM Go to last post
  26. change vin in e series bmw cluster eeprom file
    Started by neilp1990, 8th May, 2024 11:11 PM
    8th May, 2024, 11:11 PM Go to last post
  27. BMW SZL F30 (3 series) eeprom
    Started by shooperis, 8th May, 2024 02:00 PM
    8th May, 2024, 08:34 PM Go to last post
  28. peugeot boxer 2005 speed limiter
    Started by m300td, 8th May, 2024 11:08 AM
    8th May, 2024, 01:49 PM Go to last post
  29. IVECO DAILY BCM Pinout
    Started by Anass GM, 7th May, 2024 05:04 PM
    8th May, 2024, 12:49 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
