  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    14,829
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    14,112
Page 3 of 1413 FirstFirst 1234567813531035031003 ... LastLast
Threads 61 to 90 of 42389
Forum: ECU
  1. Toyota Denso NEC76F0038AGD
    Started by jewfishking, 7th May, 2024 02:25 AM
    8th May, 2024, 03:51 PM Go to last post
  2. lexus ls600 steering angle reset from eps module
    Started by karmoranas, 8th May, 2024 12:43 PM
    8th May, 2024, 12:43 PM Go to last post
  3. AUDI A6 PDC 16347 4F0919283
    Started by constan, 7th May, 2024 04:40 PM
    8th May, 2024, 08:46 AM Go to last post
  4. Ford EDC17C10 please verify eeprom
    Started by fisz8809, 14th April, 2022 08:58 PM
    2 Pages
    1 2
    7th May, 2024, 09:49 PM Go to last post
  5. VW Polo Me17.5.26 04E906057FH
    Started by ars1, 7th May, 2024 09:21 PM
    7th May, 2024, 09:21 PM Go to last post
  6. EDC17C18 OPEL check file mod
    Started by Bianko16, 7th May, 2024 04:58 PM
    7th May, 2024, 04:58 PM Go to last post
  7. ford dcm6.1 pinout eprom 25lc256
    Started by hudy26, 10th April, 2022 09:05 PM
    2 Pages
    1 2
    7th May, 2024, 03:09 PM Go to last post
  8. PSA DCM7.1A Foxflash!
    Started by khaleddaddi, 6th May, 2024 08:48 AM
    7th May, 2024, 01:55 PM Go to last post
  9. BMW X3 EDC16C35 Immo Off / Virgin
    Started by Wade123, 7th May, 2024 08:31 AM
    7th May, 2024, 01:07 PM Go to last post
  10. VW Tiguan ABS codig help
    Started by marcin7091, 1st July, 2019 03:33 PM
    7th May, 2024, 12:39 PM Go to last post
  11. VW TIGUAN 2009 abs coding
    Started by Stevens Ferreira, 10th September, 2019 04:52 PM
  12. VW Tiguan ABS coding help
    Started by hackero, 13th December, 2021 04:28 PM
    7th May, 2024, 12:38 PM Go to last post
  13. MEC32-211
    Started by tes, 7th May, 2024 11:53 AM
    7th May, 2024, 11:53 AM Go to last post
  14. fiat fiorino crash blocked fuel pump relay
    Started by prosec, 1st August, 2013 02:34 PM
    7th May, 2024, 07:51 AM Go to last post
  15. VIRGIN ECU RENAULT SAGEM S2000 RPM
    Started by drupal, 1st May, 2024 11:55 PM
    7th May, 2024, 06:21 AM Go to last post
  16. SID807EVO DS5 VIRGIN
    Started by rex89, 11th August, 2020 08:24 PM
    6th May, 2024, 07:07 PM Go to last post
  17. Ktflash experience reading E78 ECM
    Started by keycutters, 4th May, 2024 04:45 PM
    6th May, 2024, 02:56 PM Go to last post
  18. Hyundai sim2k 251 need dtc off p0011
    Started by Noumanshah8633, 6th May, 2024 12:44 PM
    6th May, 2024, 12:44 PM Go to last post
  19. Simos PCR2.1 unlock needed
    Started by brfbrf33, 5th May, 2024 06:43 PM
    6th May, 2024, 12:29 PM Go to last post
  20. Toyota Dyna 1KD 89663-25321 DPF solution
    Started by viktor0221, 6th May, 2024 10:18 AM
    6th May, 2024, 10:18 AM Go to last post
  21. URGENT ECU PHOTO, DIAGRAM ,
    Started by bursuc, 21st December, 2011 02:09 PM
    6th May, 2024, 09:15 AM Go to last post
  22. ECU Repair Helper E-Book [2023] link work
    Started by drupal, 5th May, 2024 10:11 PM
    5th May, 2024, 10:11 PM Go to last post
  23. Teansit connect pscm u3000
    Started by Hunter1206, 5th May, 2024 08:53 PM
    5th May, 2024, 08:53 PM Go to last post
  24. opel antara dcm3.7 cloning information
    Started by ASCM, 5th May, 2024 07:30 PM
    5th May, 2024, 07:30 PM Go to last post
  25. EDC17CP18 DPF / SCR Warning delete solution needed
    Started by GeorgeGG, 5th May, 2024 06:02 PM
    5th May, 2024, 06:02 PM Go to last post
  26. FILE ORIG TOYOTA AURIS NEEDE
    Started by shouari, 4th May, 2024 11:44 PM
    4th May, 2024, 11:44 PM Go to last post
  27. Need Bmw e60 2.5D full backup
    Started by mersytis, 4th May, 2024 09:25 PM
    4th May, 2024, 09:25 PM Go to last post
  28. PEUGEOT 3008 1.2 PUROTEC130HP ERR0R P1032-66
    Started by technoparc, 2nd May, 2024 08:56 PM
    4th May, 2024, 06:00 PM Go to last post
  29. Jumper SID208 virgin
    Started by matrixs11, 4th May, 2024 10:59 AM
    4th May, 2024, 04:05 PM Go to last post
  30. BMW E88 - NOX delete
    Started by felipeuk12, 4th May, 2024 01:30 PM
    4th May, 2024, 01:30 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
