  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    15,235
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    14,509
Page 2 of 1414 FirstFirst 123456712521025021002 ... LastLast
Threads 31 to 60 of 42400
Forum: ECU
  1. need ori sprinter 315cdi
    Started by prevozsa, 12th May, 2024 06:59 PM
    12th May, 2024, 06:59 PM Go to last post
  2. J34P ECU CLONE
    Started by manwac, 12th May, 2024 11:50 AM
    12th May, 2024, 06:11 PM Go to last post
  3. Mini Cooper S DTC OFF - MED17.2
    Started by GoldPritt, 12th May, 2024 01:14 AM
    12th May, 2024, 01:46 PM Go to last post
  4. simos pcr2.1 frf to bin
    Started by Cardump, 12th May, 2024 01:42 PM
    12th May, 2024, 01:42 PM Go to last post
  5. Post I can't find the ecu damper saab
    Started by Bllinda, 12th May, 2024 11:39 AM
    12th May, 2024, 11:39 AM Go to last post
  6. P0610 Error on MAZDA 3
    Started by 2me, 4th January, 2019 08:00 AM
    14 Pages
    1 2 3 ... 14
    12th May, 2024, 07:02 AM Go to last post
  7. EMS3125
    Started by talazso, 11th May, 2024 09:00 PM
    12th May, 2024, 05:57 AM Go to last post
    11th May, 2024, 10:30 PM Go to last post
  8. Post SIM271KE2.0 NEED VIRGIN OR IMMO OFF
    Started by Alexander1997, 11th May, 2024 09:47 PM
    11th May, 2024, 09:47 PM Go to last post
  9. Dump PDC Golf VI - eeprom error
    Started by milkatrek, 2nd January, 2017 08:18 AM
    42 Pages
    1 2 3 ... 42
    11th May, 2024, 09:00 PM Go to last post
  10. HELP DUMP FILE SSANGYONG ECU
    Started by Agilechaveiros, 11th May, 2024 02:30 PM
    11th May, 2024, 07:44 PM Go to last post
  11. MB W220 S320 ME2.0 and EWM need virgin
    Started by mm04kk, 10th May, 2024 02:52 PM
    11th May, 2024, 10:32 AM Go to last post
  12. EcuCorr Transit SID208 CC11 DPF Remove
    Started by Corr HexEditor, 22nd March, 2022 12:26 PM
    dpf remove, sid 208, transit
    11th May, 2024, 08:07 AM Go to last post
  13. I NEED LONG CODE CADDY ABS MK60EC1
    Started by nagybela, 4th May, 2024 10:21 AM
    11th May, 2024, 12:49 AM Go to last post
  14. Question Peugeot 308 ADBLUE OFF 0281035365 MD1CS003
    Started by dragomir, 11th May, 2024 12:46 AM
    11th May, 2024, 12:46 AM Go to last post
  15. VW Polo 6R 2012 Abs/Esp Coding 6R0 907 379 BC
    Started by kierownikszatni, 27th July, 2014 11:12 PM
    32 Pages
    1 2 3 ... 32
    11th May, 2024, 12:45 AM Go to last post
  16. Bmw dme bosch 30554 power ic pinout
    Started by Nazo, 10th May, 2024 08:07 PM
    10th May, 2024, 08:07 PM Go to last post
  17. hyundai i20 1.2 kefico /Bosch/ M7.9.8 dtc
    Started by pedro222, 10th May, 2024 04:55 PM
    10th May, 2024, 06:09 PM Go to last post
  18. A4 Steering problem B2000-00
    Started by AutoElectronicaFS, 7th May, 2024 09:07 PM
    10th May, 2024, 05:40 PM Go to last post
  19. Passat BLS i need ori file flash kess obd
    Started by mankos44, 13th April, 2021 08:32 PM
    10th May, 2024, 05:15 PM Go to last post
  20. 9gf virgin
    Started by zako32, 10th May, 2024 05:12 PM
    10th May, 2024, 05:12 PM Go to last post
  21. bosch ecu resistance edc16c36
    Started by jagl63, 5th May, 2024 10:05 AM
    10th May, 2024, 05:09 PM Go to last post
  22. kia opirus 2005 ecu reading
    Started by k_algulam, 10th May, 2024 04:50 PM
    10th May, 2024, 04:50 PM Go to last post
  23. Need immo off on pcr2.1 ecu please
    Started by expertinnotalot, 8th May, 2024 10:02 AM
    10th May, 2024, 04:24 PM Go to last post
  24. Fiat EVO gearbox ecu CFC300 pinout mcu
    Started by mapexo, 22nd April, 2019 04:00 PM
    10th May, 2024, 04:05 PM Go to last post
  25. No ground to injectors
    Started by Batts, 9th May, 2024 12:00 PM
    ecm, ground, injectors, stumped
    10th May, 2024, 03:39 PM Go to last post
  26. SID807EVO PSA read
    Started by huskypt, 10th May, 2024 10:19 AM
    10th May, 2024, 02:51 PM Go to last post
  27. Ford Kuga 2.0tdci damaged eprom haldex 5WP33531-02
    Started by arti1, 29th December, 2023 07:06 PM
    10th May, 2024, 02:32 PM Go to last post
    10th May, 2024, 12:03 PM Go to last post
  28. Corsa F 2021 MG1 pin need
    Started by metalik, 9th May, 2024 05:35 PM
    10th May, 2024, 08:06 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
