  1. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    16,647
Page 42 of 1420 FirstFirst ... 32373839404142434445464752921425421042 ... LastLast
Threads 1231 to 1260 of 42572
Forum: ECU
  1. VW JETTA ABS EXCHANGE 1K0 907 379 CD
    Started by Panathaole, 11th January, 2024 11:07 AM
    20th January, 2024, 11:37 PM Go to last post
  2. Mercedes w212 crd2.15 need virgin
    Started by volvogryfice, 20th January, 2024 09:45 PM
    20th January, 2024, 09:45 PM Go to last post
  3. Need edc15c2 flash checksum
    Started by manwac, 20th January, 2024 07:47 PM
    20th January, 2024, 07:53 PM Go to last post
  4. Mersedes W211 EDC16c2 pls virgin ECU
    Started by bsv20001, 20th January, 2024 09:26 AM
    20th January, 2024, 11:59 AM Go to last post
  5. VW UP ABSmodule long coding number
    Started by Patrick1974, 7th February, 2022 02:55 PM
    vw up abs coding problem
    20th January, 2024, 09:13 AM Go to last post
  6. Need Calculate the checksum simos3.3a
    Started by jonibiss, 18th January, 2024 08:22 PM
    20th January, 2024, 07:54 AM Go to last post
  7. BMW F.S DME MEVD 17.2.8 ISN from DUMP and thanks
    Started by alameer, 19th January, 2024 12:08 PM
    19th January, 2024, 10:51 PM Go to last post
  8. Please firmware for my 8K0953568F Audi Q5
    Started by Hechizo, 19th January, 2024 02:49 PM
    19th January, 2024, 06:05 PM Go to last post
  9. Question Land Rover eka code
    Started by vladzaj67, 19th January, 2024 03:48 PM
    19th January, 2024, 03:48 PM Go to last post
  10. Skoda Octavia 2002 need immo off
    Started by sergiooo, 19th January, 2024 02:27 PM
    19th January, 2024, 03:43 PM Go to last post
  11. EDC16C36 DF025 fault
    Started by marjan76, 18th January, 2024 06:21 PM
    19th January, 2024, 03:35 PM Go to last post
  12. Golf 7 TCU DQ250_MQB EEPROM and FLASH
    Started by bokilee, 19th January, 2024 01:47 PM
    19th January, 2024, 03:10 PM Go to last post
  13. ecu mini cooper mevd17.2.2 no communication
    Started by bassit, 19th January, 2024 11:30 AM
    19th January, 2024, 03:04 PM Go to last post
  14. Chevrolet Captiva 2007 BOSCH M7.9.9 2.4 136lc 0261208782
    Started by ssebastyan, 16th October, 2016 10:53 AM
    19th January, 2024, 12:55 PM Go to last post
    19th January, 2024, 12:41 PM Go to last post
  15. Megane MK3 UPC diagram
    Started by jolor, 21st October, 2018 12:59 AM
    19th January, 2024, 12:20 PM Go to last post
  16. audi a4 8k0909144B steering dtc B2000 00 ,B2000 42
    Started by cudzy, 18th January, 2024 02:16 PM
    19th January, 2024, 12:15 PM Go to last post
  17. Audi A4 B6 DTC off
    Started by iluzion, 19th January, 2024 07:48 AM
    19th January, 2024, 12:01 PM Go to last post
  18. Fiat doblo Ecu 6df EGR OFF
    Started by techcar1992, 19th January, 2024 08:00 AM
    19th January, 2024, 11:09 AM Go to last post
  19. Peugeot 508 sid807evo need check maps
    Started by JeyTi, 19th January, 2024 10:48 AM
    19th January, 2024, 10:48 AM Go to last post
  20. Peugeot 508 med17.4.2 virgin 0261 s06 632
    Started by barcio, 19th January, 2024 09:56 AM
    19th January, 2024, 09:56 AM Go to last post
  21. Renault modus 2005 fuse box
    Started by Badfoxer, 19th January, 2024 07:27 AM
    19th January, 2024, 07:27 AM Go to last post
  22. mercedes ML dpf issue
    Started by carapauxxx, 19th January, 2024 07:07 AM
    19th January, 2024, 07:07 AM Go to last post
  23. Renault Petrol ECU Valeo V50
    Started by henkgr, 18th January, 2024 09:42 PM
    18th January, 2024, 09:42 PM Go to last post
  24. renault simbol 2010 AT 8200392714 S110140202A immo off
    Started by alaaengineer, 18th January, 2024 08:33 PM
    18th January, 2024, 08:33 PM Go to last post
  25. Need info on Toytota Dyna 89661-25060 ECU
    Started by Msmax, 18th January, 2024 03:35 PM
    18th January, 2024, 03:35 PM Go to last post
  26. Audi A4 8K0953568F Steering angle
    Started by chafik4051, 18th January, 2024 12:12 PM
    18th January, 2024, 02:59 PM Go to last post
  27. need Help Ecm Magneti Marelli 9GF Gasoline/Tipo 2020
    Started by The Stage, 16th January, 2024 01:59 AM
    18th January, 2024, 01:50 PM Go to last post
  28. Passat b6
    Started by Vlasto, 18th January, 2024 10:09 AM
    18th January, 2024, 12:16 PM Go to last post
  29. Fiets MK5 1.4tdci
    Started by Robert34, 18th January, 2024 11:12 AM
    18th January, 2024, 11:12 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
