Results 1 to 6 of 6
    Apr 2013
    United Kingdom
    Default HOW TO DISMANTLE RENAULT LAGUNA 3 MEGANE 3 DOOR LOCK CYLINDER
    I searched everywhere to find some info on dismantling this lock with no luck, but thanks to @newone for helping me out. And also big shout out to @rapidlocksmith for educating on how to decode these locks the proper way.
    https://www.digital-kaos.co.uk/forum.../488063-newone
    https://www.digital-kaos.co.uk/forum...apidlocksmiths
    please thank + rep them too
    Hit like and thanks if I've helped you!!
  2. The Following 3 Users Say Thank You to urcarpc For This Useful Post:
    fuzz1 (12th January, 2023), Weasel3 (14th January, 2023), wuza (15th January, 2023)
  3. #2
    Apr 2013
    United Kingdom
    Heres more pictures
  4. The Following User Says Thank You to urcarpc For This Useful Post:
  5. #3
    Apr 2013
    United Kingdom
    Last set of pics
  6. The Following 2 Users Say Thank You to urcarpc For This Useful Post:
    fuzz1 (12th January, 2023), wuza (15th January, 2023)
  7. #4
    p1et's Avatar
    Oct 2013
    Mate, you should create a book . That's what we call clear explanation Although I dismantled this and remember, I highly appreciate your effort and quality of that work.
  8. The Following User Says Thank You to p1et For This Useful Post:
    urcarpc (12th January, 2023)
  9. #5
    TeL200's Avatar
    Mar 2010
    Worcester UK
    Easier way to remove circlip (Truarc) is drift out pin that holds tail piece (Paddle) remove tail piece to reveal socket, drill small hole (in correct place) and with suitable tool push circlip out.
    But learning to use Lishi is much quicker
    Auto Locksmith / Security Professional
  10. #6
    newone's Avatar
    Oct 2016
    as @TeL200 said but you must be a little more carefull,also after take of safes you can take out inner casing with cylinder,press waffers in rotate and the cylinder comes out from its inner casing
  11. The Following User Says Thank You to newone For This Useful Post:
    TeL200 (14th January, 2023)
