Results 1 to 15 of 15
    Jan 2023
    Default EDC17C56 (BMW N57D30) Missing Some Maps
    Hi All,
    I'm a hobbyist mechanic from Europe, working on my own/friends cars. I'm driving 3.0 diesel (258hp, 560nm) with EDC17. I have some experience with EDC17C50 ECU as I had a BMW 316d before, but EDC17C56 is a bit different. I'm trying to create myself a stage 1 tune, but for whatever reason I couldn't pass 560nm. I've already defined almost 100 maps in WinOLS and modified some of them, including the following:
    1. Requested Torque by Variant (22x4)
    2. Maximum inner engine torque monitoring (1x1)
    3. Driver Wish (AWD and Standard, 14x8)
    4. Maximum inner engine torque (23x1)
    5. Torque Limiting Map (22x4)
    6. Sport Display Adjustment (1x1)
    Still, I'm getting only 560Nm. The car has 8 speed auto gearbox. What I'm missing? Any ideas? Attaching both original and modified BINS.
    Any help very much appreciated!
    gadelhas's Avatar
    Sep 2012
    Portugal
    I mate, you dont touch on almost all critical maps to make stage1 ,
    miss:
    lambda maps
    drivers wish
    single valeu torque limiter
    gear limiters
    duration
    torque to fuel
    Turbo pressure
    torque monitoring
    etc...
    this is ecu have to many maps do mod.
    if you begining on remap world a advise you start on easy cars like some edc15 edc 16
  3. The Following User Says Thank You to gadelhas For This Useful Post:
    Arnold13 (13th January, 2023)
    Jan 2023
    Quote Originally Posted by gadelhas View Post
    miss:
    lambda maps
    drivers wish
    gear limiters
    duration
    torque to fuel
    Turbo pressure
    torque monitoring
    etc...
    Thanks for the reply. I tend not to touch the maps that are not needed. Therefore, I haven't modified the Driver Wish map because it is not limiting:
    So, at 100% throttle it requests up to 648 Nm, which is fine for me.
    Same goes for lambda, I.Q. duration, torque to fuel maps and turbo pressure: no real need to modify them, as they are scaled enough in the stock firmware. Since I don't have "check engine" issues, I doubt that torque monitoring kicking in as well (and I've modified at least 1 SVTM and 23x1 map):
    Based on that, I think that I'm missing some SVTLs (they are very hard to find, because there are a lot of 2-byte values there, hard to pick the correct one) and maybe gear limiters (I was able to find them in EDC17C50 with manual gearbox, but not on EDC17C56 with auto). Here is how they look like in my 316d map (just for the reference that I know what I'm talking about):
    So, still, any input is very much appreciated.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    You measure Nm in sport display or diagnosis?
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  6. #5
    gadelhas's Avatar
    Sep 2012
    Portugal
    SVTL 36FA7C 1X1
    Torque limiter 3703D2 4X23
    Torque monitoring 3016BB 8X14
    Torque monitoring 301740 8x14
    Gear Limiter 3C83FA 4x1
    SVGL 3C8396 1x1 (Dont need touch already 1000nm)
    VSS SWITCH 38D53D 1X1
  7. #6
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    SVTL 36FA7C 1X1
    Gear limiter 380? Svtl 350nm. They are not used at all..
  8. The Following User Says Thank You to Ignasvw For This Useful Post:
  9. #7
    gadelhas's Avatar
    Sep 2012
    Portugal
    you´re right its low torque limiters.
    if the car is stock with DPF maybe can be back pressure limiter or exhaust temps, do not allow reaching request torque, Arnold13 take a look on this ones:
    Torque limiter back pressure 36FD1C 8X13
    Torque limiter by exhaust temp 36FE4E 8X12
  10. #8
    gadelhas's Avatar
    Sep 2012
    Portugal
    or you have on TCU a limiter on 560 NM
  11. #9
    Jan 2023
    Quote Originally Posted by Ignasvw View Post
    I'm using VehiCAL high speed datalogging and the numbers are more or less aligned with the sport display measurements.
  12. #10
    Jan 2023
    SVTL 36FA7C 1X1
    36FA7C - its 350 Nm in stock map, could not be limiting, because engine outputs 560Nm
    3703D2 - this is a Starting torque limitation with closed compressor bypass - could not be limiting, all the values in 1500-3000 rpm range are above 630
    3016BB (I guess you've meant 3016B8) - I see the map, but could not understand the axis and factors. Same for 301740.
    3C83FA - 380 Nm, could not be limiting because engine outputs 560Nm
    3C8396 - Not relevant
    38D53D - VSS is not an issue
    36FE4E - mostly not limiting past, because DPF operates at lower than 500 deg C. At 1500-3000 it gives more than 700 Nm. Anyway, checked and edited. No result.
    Not the case. Local tuners just upload stage 1 firmware on the same car as mine, without any TCU reflash and achieve at least 630 Nm.
  13. #11
    gadelhas's Avatar
    Sep 2012
    Portugal
    3BBC44 FUEL TEMP
  14. #12
    Jan 2023
    3BBC44 FUEL TEMP
    What about it? I have this map defined as well. On everything less then 84 degrees C it is not limiting after 1000 rpm. I don't know what you need to do to get a diesel fuel up to 84 degrees. Mine is around 40 C in the logs.
  15. #13
    Jan 2021
    Germany
    http://prntscr.com/yzWwy-U_H4Zr
    These should be all limiters, 3D3FB0 maybe isn't used. I also included the sports display maps.
    Dont forget that NM to IQ and few TQ Limiters use internal torque.
    If you need help pm me. With proper stage1 autobahnsafe 680-700nm are possible .
    edit:
    forgot 36FC9C TQ limiter 8x1
  16. The Following User Says Thank You to werner1337 For This Useful Post:
    Arnold13 (14th January, 2023)
  17. #14
    Jan 2023
    Quote Originally Posted by werner1337 View Post
    Thanks a lot, man. Really appreciate your effort! The only maps that I were missing are 3 SVTL (the most hard type of maps to find for me): 354DE2, 3711B4 and 3D3FB0. Since 354DE2 (710Nm) and 3711B4 (656.9Nm) are not limiting, I think it could be 3D3FB0 (560Nm in my stock bin) after all. I'll report back after checking it out.
  18. #15
    Jan 2021
    Germany
    If you want I have a complete map pack for this SW from a X3 F25 :-)
    Oh and I forgot
