Does anybody have "open" Fiat tool from smok for testing?
Thanks...
yes i have
I have too... but my interface has no serial no.
I bought from Smok about two years ago, it's original.
But... it hasn't described functions...
Look the screenshot.
szkeptmen
Polak, wegier dwa bratanki i do szabli i do szklanki
Contact your smok dealer...
Or just in case check the board and all connections... Reflow the board and replace usb cable or check the connections on the cable...
As far as I know it myst show the serial if the unit powers up and is connected properly...
Good luck...
has someone already tried it with orig, interface ??
Hey Guys,
Tell me something because i don't understand.
Is any of you make to some of Smok's software run on simple KKL interface ??
VAG
Somebody tried to unlock Fiat / Renault tool made by Smok ?
It would be nice...
this is NEC based interface
NEC based... impossible to unlock ?
Or very hard ?
I have original interface, just need some functions
Szkeptmen have right ,good idea..I was search for datasheet for this NEC but nothing. Its marked as NEC MYS 503T ( maybe coded like Bosch ) what is right mark this IC? OK this is uPD78F0503 but is one problem...reading flash command not exist.
