Good morning to all. is there a tytorial for this program here in the forum; efcharistto you very much for your time
Hello any one try to change odo on dash with Magic Dash X Can on Audi A6 2009+ ?
I get read km ,and then when i try to write i get input start hex value
yes, it works.
write 0
if when program search security key interrupt hten You can start from interrupted value - You don't must start again..
I don't undesrand excatly how you said.
Did you test it?
Yes i test it by myself.
I had the same problem, i ask smok engineer and he tell me to write 0.
Wenn program get interupt by programming new mileaged, look at moment it`s interupted and start programming again but now start at the interupted value.
SOw after i write 0 will start programming and then will stop programming and i must retry from the specified new value?I don t see this sow safety option...
No, normally programming wil not interupt and you have to do nothing, but wenn it interupt you start programming again but not at value 0, but at value were it stopped before.
Thank you.I will test leter,i hope i wll not corrupt the eprom file
Some time ago I tried to change EDC16 on older Touareg 04 I think...
Dash was ok, but I was not able to access EDC16...
This is what I got:
Communication Init OK
VIN: xxxxxx
BOSCH 0281011258
Securit Acces OK
Read Error !!!
And it stops right there...
There is also a strange symbol on the end of INFO.... See attached pic...
Anybody had any problems like this before?
I must add that MDC worked on other EDC16 but it does not work on this one, however that was through MDC x-can and this one is through MDC... It is original full licensed hardware from SMOK...
How to access this EDC16 using SMOK?
VCDS reads EDC16 mileage without any problems...
No one tool work on all edc 16 versions but are you tryed with Can option?
This is Magic Dash CAN V3.83.0.1 by SMOK, modified to bypass the following messages below
You must buy this function-contact seller
You must buy this Fuction !!!!
You must buy License Level 2
You must buy License Level 2!!!
You Must Buy Level2
I have disabled the online update check it does at the beginning, i have done this cause if they release a new update the program will go and update itself if you are on online and it rename the modded exe.Just extract MDCDK.exe from the archive to C:\Program Files\Magic Dash CAN -XCAN and create shortcut to desktop, that way you have modded and original to select from.
This has not been tested, as always use at own risk.
Pass:Qutomotive
Impactops
