    Feb 2023
    Default EDC16CP34 DPF OFF Help
    original file.rar
    Hello everyone.
    The car is Audi A6 C6 3.0 V6 TDI ASB with EDC16CP34. Im wondering if it is good solution do to DPF OFF with single switch and disconect the 2 temp. sensors and the diff. press. sensor. Greeting.
    Jun 2020
    Post file i ll do good solution for you.
    File service, Custom Remapping, stage 1 & 2 dyno tested.
    Petrol + Diesel
    Adblue dpf egr Only tested working solutions.
    Use thanks and Rep if my help was helpfull.
    qni666's Avatar
    Mar 2019
    Bulgaria
    Quote Originally Posted by SeatIbiza7 View Post
    Hello everyone.
    No problem manual solution, but without file from nobody can help u
    NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
    No files for users who not give feedback or new registred users for free file service like as :
    Okinux,duzaven,1mmortal
  4. The Following User Says Thank You to qni666 For This Useful Post:
    stanislav georgiev (5th February, 2023)
    stanislav georgiev's Avatar
    Oct 2014
    България
    EDC16CP34 I think it won't do with one switch
    qni666's Avatar
    Mar 2019
    Bulgaria
    Your file is not original bad remap try from someone in first codeblock touched only 1 turbo map and limiter, second codeblock have bad try to remove egr for that reasoh u have problems with dpf and have bad mod in Injection duration cr. 1 table of 2 maps tq limiter and not full gear limiter touched anyway i stop only dpf let tool to make checksums here is my manual solution for DPF and disconnect Differential pressure and temperature sensor
  7. The Following 3 Users Say Thank You to qni666 For This Useful Post:
    SeatIbiza7 (6th February, 2023), stanislav georgiev (6th February, 2023)
  8. #6
    Feb 2023
    Thank you very much i will try it on car tommorow
