Results 1 to 2 of 2
    Apr 2022
    Default Renault Kangoo EDC17C84 DPF off
    Hi, I need to deactivate DPF on a Renault Kangoo 1.6dCi K9K with Bosch EDC17C84 injection. I already tried a manual solution without success. The car behaves strangely, when throttle is suddenly applied it hesitates or jerks. You can really hear the turbo spooling and stopping. I don´t know if this problem is related to the file itself. It could not be properly tested tˇwith the original file as the car goes into limp mode due to a faulty diff pressure sensor.
    Attached ori and dpf of attempt.
    Default DPF EDC17C84
    The differential pressure sensors and the temperature sensors must be disconnected.
    Perform all resets before you write the file
    TRhanks and rep please
  3. The Following User Says Thank You to waylyn For This Useful Post:
    dierus (4th October, 2023)
