Results 1 to 11 of 11
    Apr 2022
    Default Audi A4 2001 IMMO
    Hello all,
    i need help to find the IMMO Pin from this file. I change the KI but anyone has remove the Airbag Lamp and the KI now its scrap....
    How i can change the Mileage of this? It's a Magneti Marelli (Jäger) KI, i don't know to change this...
    I think the Pin is (0) 2184 ?
    Oct 2020
    Bulgaria
    yes, your pin is correct. what target mileage you want?
    kiszka's Avatar
    Quote Originally Posted by pyromaniac View Post
    Hello all,
    this is not a valid pin
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  4. The Following User Says Thank You to kiszka For This Useful Post:
    brend (14th February, 2023)
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by evgeny87 View Post
    Mate , dump 65 Kb !
    Pin correct .........Realy .......... ?
    Oct 2020
    Bulgaria
    Yes, pin is correct. Think little bit before post.
    Its immo2 here full immo
    8D0 920 900 M
    VIN XXXXXXXXXXXXXXXXX (no vin)
    ID AUZ5Z0B2098043
    LOGIN 02184
    CS 121F3A607E92BA
    KEY 1 445FB6FE
    KEY 2 2E643AB4
    KEY 3 445FB530
    KEY 4 2E6437F5
    Mileage 325791
    kiszka's Avatar
    8D0 920 900 M
    ID AUZ5Z0B2098043
    LOGIN 02184
    CS 121F3A607E92BA
    KEY 1 445FB6FE
    KEY 2 2E643AB4
    KEY 3 445FB530
    KEY 4 2E6437F5
    Mileage 325791
    That's all It's me I know
    Reality of life :
    3:Everyone lies
    Apr 2022
    Sorry, i'm stupid, i see this was .bin from old KI, not new.
    Now Attachments it's the .bin from new KI, the Mileway from this is 400935 km, but must have 325840 km, how i can change this?
    The Seller give me Login 01292 for this KI, it's right?
    Thanks very much for help.
    Oct 2020
    Bulgaria
    Hi your new cluster pin is wrong. Correct one is 00626. If your adaptation with vcds is not sucessfull i can transfer your immo. I sent you on p.m your new cluster file with 325840KM. Share results.
  10. #9
    Apr 2022
    Thanks, the Code 00626 is right, succesful learn new key.
    But i write the new Cluster on KI, it's also the old Mileage 400936 KM...
  11. #10
    Apr 2022
    VAG K+CAN Commander ask me this box, it's right? I didn't change this. The Cluster write 5 min, but not change the Mileage...
  12. #11
    Oct 2020
    Bulgaria
    Yes, because you dont write the file correct. here is writen on one of my test dashes. File is ok. Send me p.m.
