Results 1 to 4 of 4
    Sep 2016
    Japan
    Default Duster_Arkana R7F71400 RH850 black_display odometer
    i try made the odometer correction to duster 2020 R7f71400 with Stool by obd, the eeprom info was erase, the programmer changed the km and not return the backup file.
    checking the files the eeprom is partial read by Stool
    i need pinout or connections to read the MCU
    i try vvdiprog with picture help, dont working
    the recommendation 5V and 8mhz dont working.
    i accept any comments.
    Equipment
    VVDI prog
    UPA-S
    Xtool programmer
    Stool
    thanks a lot
    Sep 2014
    You can kill cpu if try write by uart.
  3. The Following User Says Thank You to Geryy For This Useful Post:
    agudelui99 (22nd February, 2023)
    Mar 2017
    Colombia
    Quote Originally Posted by agudelui99 View Post
    Equipment
    VVDI prog
    UPA-S
    Xtool programmer
    Stool
    thanks a lot
    Hello friend, it's just to keep it in mind.
    Do you use stool?
    Which version _______ Is Original _____
    I'm worried because this hasn't happened to me.
    WINNER THE LOSER
    carradio2001's Avatar
    France
    Try this from Orange-5.
    You solved it ?
    BR,
    Carradio2001.
  6. The Following User Says Thank You to carradio2001 For This Useful Post:
    tanon (9th May, 2023)
