Results 1 to 7 of 7
    Default Mileage Opel Omega
    Simply curiosity.........Opel omega (for example year 1999) cannot be done with tacho universal?????? I have not found it in database...........probably it has same cluster that a vectra but I am not sure.
    Its only curiosity.....because I have not seen on list.
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by GolfmkI View Post
    I think opel omega is in the menu, if not;
    Car type: Opel Omega - 93c46 - 1999 year
    The mileage is stored in the next lines:
    0000: 0F 9F 0F 9F 0F 9F xx xx xx xx xx xx xx xx xx xx
    where the next bytes:
    0F 9F - is a mileage
    same as senator 1999
    Probably it is in the menu of tacho universal, but I only have looked for pdf to see instructions.....I suposed it can be done without problem....so thanks...if in the future i have to do someone I will do directly programming 93c46 without tacho universal.
    Opel Omega instrument cluster milage it mechanical indicator (not digital) !
    I am not sure but I think 1999 model already has digital indicators.......
    drpeter's Avatar
    The Netherlands
    1999 is digital and I looked in diga menu and yes its there, its called omega > 93C06 that eprom is same as 93c46
    And if that don't work you can always read the eprom with diga and sent the dump on this forum, so we can do it for you. Life is simple.
    Sep 2013
    one question
    when I change omega eeprom in 93c46 , its change mechanically Numbers on dash , or i should replaced km numbers by hand on dash ? picture -->
