Results 1 to 7 of 7
    Oct 2008
    Default "Fatal Error couldn't open servicefile create /var/tuxbox/config/enigma"
    I get this error message "Fatal Error couldn't open service file create /var/tuxbox/config/enigma" when scanning db 500c for services, please tell me why?
    Thank you in advance
    Jul 2008
    most likely you have a corrupt image - a reflash would fix it.
    Oct 2008
    This may be relevant or just a coincidence but since no longer copying the picon folder this error message has disappeared...I'm just copying scce and keys folders.
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Images can get corrupt if there is no space left in the /var section. A picon folder wouldn't use up that amount of memory but if you have loads of plugins and a few emu installed as well, that might be the cause.
    Or it might just have fcuked up for no reason ...
    Most likely the reflash cured it.
    Jan 2009
    Quote Originally Posted by Devilfish View Post
    Yes ... I agreed with Devilfish said ... problem cause image corrupt and no enough space of memory in the /var section ... try to re-flash
    I have faced that's problem before ...
    i have same problem. is there any way to delite some file to make some space? or if the images corupt is there no chance to fix it beside reflashing?
    Jan 2011
    nabilo darkstar 2 i had to delete 2 plugins i downloaded to get past this thanx devilfish
