Results 1 to 2 of 2
    Feb 2023
    Exclamation 2002 Honda Accord IMMO 37820-PDA-E11
    Hi!
    I have an european Honda Accord and i want to copy my keys from one ECU to another because the original one is water damaged.
    I know for sure that the immo info is stored in the ECU somewhere, but i cannot find it where.
    I found only one 93LC46 EEPROM in the ECU, read it and that is not the immo data.
    Where else could it be?
    On the vertical PCB there is a big IC but i cant find anything about it on the internet.(also the vertical PCB has MEGAMOS written on it.)
    Any ideas where immo data could be stored?
    Jan 2023
    There is no key data in that ecu, only alignment data from immo ring on ignition
    1. Copy the data on that 93lc46 eeprom then write to donor ecu. Car will start.
    2. Use programming tool like vvdi or autel or abrittes then marry the donor ecu to immo ring(make sure all keys are present when doing this)
