and what make with zgw bsg(batterysteuergeraet)and
ecu(particelregeneration)
ak400 is for key make(bad tool from china)
batteri modul read milage from odometer no problem!
Particelfilter just restart particelregeneration with star diagnostic
I just want to connect wires would not know
Hi. I would like to know how the wires from AK400 are connected to the EZS? If it is possible i like to have the schematic diagram of these wires connecting A400 To EZS. thanks again for helping.
Forget about AK400, you can bloack your EZS or zgw when using it, be carefull, i damaged couple of ezs like this.
Use Rosfar programmer "bmw 912 programmer" (blue case), it's the best way, you have on board connection wire to read write it, and it tells you when connection is wrong. AK400 does not !
Good Luck.
yes ok hello
In W211 the mileage is stored in many other modules besides CGW, EZS and Dashboard!
If you didnt do before any of this EZS beware .
If you want to do it anyway upload the photo of your EZS to tell you the solution how to connect it to the AK400.
Upload the eeprom dump containt of Dashboard too.
Upload the photo of ZGW ,I will try to help you to read ,after you will need to correct service data on it.
Hi friend!
I tray connect on number, but AK400 dont work.
I tray connect on color, AK 400 start read, but dont possible. I connect 0-Black - graund, 2-red - Power, 4- Yelow (Reset), 7- purple (BKDG), but i dont know White (Extal), may be 9. I write http://www.digital-kaos.co.uk/forums...-ak400-118754/ but i dont have answer.
Hello ,
i have AK400 V2 but it can read W211 EZS , any suggestion ?
