Page 12 of 12 FirstFirst ... 2789101112
Results 166 to 180 of 180
  1. #166
    Apr 2012
    good question!
    who killed President Roosevelt?
  2. #167
    Apr 2012
    Wonderland
    faster and easiest way for decode:
    cut immo line (pin 37 1.4 and 1.6, pin 35 1.8 and 2.0L)
    find flash
    connect ecu to car and switch ing on
    short circuit to ground for few to ten times pin 22 for flash 28F512/29F010
    short circuit to ground for few to ten times pin 23 for flash 27C512
    start the car
    ProTuner since 1999
  3. The Following 3 Users Say Thank You to atomiczen For This Useful Post:
    a35l35 (13th January, 2020), gelomeloman (29th November, 2017), pawelelectro (2nd April, 2015)
  4. #168
    DK Veteran elecautocr's Avatar
    Hi Members:
    I tried the method #1, light stop blinking and now is always ON, I tested the ecu on bench, the 2 pins for injection control are working (pin 4 pin 30) fuel pump relay is workin too, but I don?t have coils activation signal on pins 28 and 29.
    Do any of you had this problem ??
    Maybe bad TMS erasure or bad coils stage output ??
  5. #169
    bangreno's Avatar
    Oct 2011
    Tried this method many times with renault engine , worked 100%
    Now have in Hand Hyundai Siemens H103955556A , not working with these two method , tried with ecu deconding tool , selected standard mode , not working.
    Can somebody clarify immo system and wiring for hyunda elanta coup? , 1.6V.
  6. #170
    Jan 2011
    Hi, this is for 28F512 rigth? you have work with 27C010 on fenix 5?
  7. #171
    salkapone's Avatar
    Oct 2013
    Thanks to the solution ,,,works,,,,,, tested on two cars
  8. #172
    abu deab's Avatar
    Do we separate 1-9 for flash28f512 or what Blcaml Please illustration
  9. #173
    dadal's Avatar
    Aug 2015
    hi to all,
    I always take a backup of Flash before I make it immo off, How can I make a backup of fenix5 without desoldering Flash ??
  10. #174
    May 2013
    Hi there Guys.....
    I have a problem. This is the second time I have a Megane Scnenic with the FENIX 5 ecu. When I connect the ECU as per diagram the MIL Light Doesn't Flash nor come on. I Checked all wires but nothing.
    Does it require high power or what? I am using a 12V 7AH Alarm Battery and these small Jumper leads with Crocodile Clamps on the ends.
    Any Other suggestions???
  11. #175
    i cant downloading it
  12. #176
    Dec 2017
    TÜRKİYE
    megane solution very simple2.rar and soultion2fenix5.rar are not open.
    please send again for me
  13. #177
    Dec 2017
    TÜRKİYE
    I CAN NOT REACH THE FILE
  14. #178
    Jul 2013
    Quote Originally Posted by Emre28 View Post
    buy a renault decoder for
    SIEMENS FENIX3B BOSCH MSA15.5 (DTI)
    SIEMENS FENIX5 BOSCH EDC15C3 (DCI)
    SIEMENS SIRIUS32 LUCAS DCU3R (1.9D)
    SAGEM SAFIR (55pin) Coded fuel cut-off valve (1.9D DDS)
    SAGEM SAFIR2 (35pin)
    BOSCH MOTRONIC MP7.0
    MAGNETI MARELLI IAW 06R
    MAGNETI MARELLI IAW 8R.30
  15. The Following User Says Thank You to petronijul For This Useful Post:
    rumentil58 (10th May, 2018)
  16. #179
    Dec 2019
    Thanks for this method
  17. #180
    Member centrozax1's Avatar
    Dec 2019
    Montenegro
    Im sorry for waking this old topic but im hoping that someone can help me...
    Problem is:
    Renault Megane Coupe 1998 2.0 16v 103kw
    Replaced uch(ucp) from inside the car, in top of pedals but car wont stard because immo flashing red on dash. After that some mechanic comes with diagnostic and turn the immo off and flashing light gone but car again wont start just cranking. After this solution i see that "zig zag" flashes all the time and now we cant connect diganostic to read ecu and even ucp(uch)...
    Can anyone point me in right direction do I maybe need to do solutions from start of topic after turning immo off on diagnostic?
    And I need to to this can someone post solutions how to do it because i cant download attached files from start of this topic...
    Thanks in advice
    Attachment 942800
