Results 1 to 4 of 4
    Nov 2022
    Default VW Premium 3D cluster EEPROM VIN change
    Dear all,
    I'm in a cluster swap in a 2008 Scirocco from a small red display cluster to a premium 3D cluster.
    The immo is disabled in the ECU and in the cluster, but the VIN number isn't mach so I can't calibrate and code the ABS.
    If I put back the original cluster everything is good, but with the new one I can't calibrate the brake pressure sensor and the other ones... So I need to change the VIN number in the cluster.
    In VAG Dash editor there is a table reference where is the VIN number in the eeprom, but if I open the hex with an editor, it isn't the clear VIN in ASCII coding.
    It is possible to change the VIN with any hex editor, or I need VVDI to change it?
    Thank you,
    Best regards, Tomi
    Aug 2018
    Vvdi uhds avdi
  3. The Following User Says Thank You to vas100 For This Useful Post:
    flatron11 (22nd March, 2023)
    Oct 2014
    Netherlands
    Only by OBD using a suitable tool.
  5. The Following User Says Thank You to H2Deetoo For This Useful Post:
  6. #4
    Nov 2022
    Thank you, I have read about it and these codes are encrypted, so yes, it needs a specified tool.
