Results 1 to 4 of 4
    Oct 2016
    Argentina
    Default Yamaha Tracer 900 Denso 2SC-8591A-00 Writing
    Hi there! Im need to flash a Yamaha tracer 900, Denso 2SC-8591A-00. I undersant that in order to read this ECU I need to drill a hole iin the ecu and I prefer not to.
    It is possible to get the stock bin file online, make the mods and flash the ECU. The motorcycle would start? What about the inmo? Any help?
    Thanks a lot!!!
    Mar 2021
    FRANCE
    Quote Originally Posted by agiesenow View Post
    Salut ! J'ai besoin de flasher un traceur Yamaha 900, Denso 2SC-8591A-00. Je comprends que pour lire cet ECU, je dois percer un trou dans l'ECU et je préfère ne pas le faire.
    Il est possible d'obtenir le fichier stock bin en ligne, de faire les mods et de flasher l'ECU. La moto allait démarrer ? Qu'en est-il de l'inmo ? De l'aide?
    Merci beaucoup !!!
    Hi ! to flash you can use an ori file I must have one.
    for the immo and the setting you can buy an xdf.
    I am currently looking for the immo for this ecu.
  3. The Following User Says Thank You to Tonyvalero For This Useful Post:
    agiesenow (21st April, 2023)
    Oct 2016
    Argentina
    Quote Originally Posted by Tonyvalero View Post
    Thanks for replying! I arready did and it works perfectly! About de inmo; I have a dimsport "definition" that applyies a patch for the inmo, I can check in a Hex editor whast address modify and the value it applyies if you want..
    Resgards,
    Mar 2021
    FRANCE
    after looking for a long time the immo is easy to find it is a logical hex sequence 0F000A it is valid on all yamaha ecus..
    I was able to do the test on a few ecu
