It looks you have clone box and may have wrong drivers for tuner.
Reflash box with patched image. It should help you.
First time I have posted and still learning the ropes.
Just bought 2 DM800 HD's
I have 1 working fine (even after bricking them both, CA Error!)
The 2nd will not display the Tuner, during setup.
When I go to Service Searching > Tuner Configuration > Choose Tuner > Tuner A: (Empty) > nothing
Now I know the tuner itself is fine as I put it in the 2nd box and it works. I have also tried several variations of BL72 and Images to no avail.
Does anyone know if this is a Software or Hardware issue?
Would appreciate any help you can provide.
It's driving me crazy! and I am reluctant to send it back to China.
Cheers
Hi acatech, thanks for the reply. I do have a clone box, 2 of them. I know the tuner works fine in the other box. I have tried various patched images and bootloaders. Would they sort out a driver issue for the tuner?
Can you install tuner drivers on their own? The box boots up fine and goes online, it just won't see the tuner to pick up a signal.
Any ideas?
Cheers
sounds like a main PCB issue. Maybe even drys on the tuner input ?
just beware if you cant repair yourself
Chinese law means that you can't send a fully assembled product made in China back into China
Hi cauliflower69, thanks for the reply.
* sounds like a main PCB issue - Can I fix this, myself?
* Maybe even drys on the tuner input - Can I fix this myself?
Any knowledge you have on this would be very much appreciated.
Cheers.
Hi Southpaw, thanks for your response.
Does that mean I can't return it?
When I contacted the company concerned, they said to return it to them and they would replace it.
Are they telling porkies? Should I just try and fix it myself?
Cheers
Hes tried that already I think. If I was you I'd post it back. I returned a unit before and got it replaced just fine.
I wouldn't mess about with it as you'll find that if you do you may void the warranty.
Jay , was the tuner working before you got the "no ca error" ?
Guys, I appreciate your replies.
The tuner has never been working on that box, but works fine in the other one, so I know the tuner works. I got the CA Error, after installing a dodgy image, straight out of the box, so never tested it before I flashed it.
Its sooo frustrating, as everything else works fine on it. Nervous about sending it back and loosing my dosh!
It must be fixable, but so far every attempt has failed.
Can you install driver files exclusively for the Tuner?
If so, where do I find them and what should I use?
Cheers Gurus
Read this thread, and believed my tuner/box (clone) was not working due to exact same issues/message. But after installing patched image/firmware Dream Elite Black Holde 1.3 everything is working perfect. So clones needs patched image it seems.
i had a problem like that on a clone
i think i used dreamup not networked ,in the end if you havent already with an older image
like nabilosat 0.9 or 0.10 to start with
