with some boxes cable connectors may be loose check connected and secure.
presume you mean the cable connectors between the power supply board and the circuit board, have checked these and are OK,
on starview and digivox they went to led panel on front.
one does come of the circuit board and onto the led board, already checked that one and ok
Starview Diagnostics & Repair - Jtag, "0" problem, freezing, no power, random restart
repair shop,not used but worth a shot
thanks, might be worth a shot
Has anyone used the starview diagnostic and repair service provided by the link in the earlier thread response and if so are they ok
Out of interest has anyone still got PVR THE BOX up and running with all channels,since the last big encryption i have failed to pick anything up,i did have it on a splitter but even using direct feed/having the latest firmware(2008) and trying the old original versions i still only find 70 channels max, all tv with number channels that are blank/scattered..purely out of interest
teeside area btw ;D
are you scanning and pulling in max number of channels,but many of them are not working,there is a nagra3 post around forum check it out as if your on the list you will be losing them all.
mine works ok but when turned of at the plug the sound goes good picture have to reflash it any ideas
