Hello to all !!
I'm looking for dump to on Laguna II ?
I can't read the ?C 908AZ60 (need a security bit) !
Did you succeed in? With witch tools
Thx
Hello to all !!
Thx
Thx tachonow,
Is upa usb programmer the right tool for the tacho dumps on those dashboards embedded with 908 motorola ?
Do you use it ?
Do you need extended programming adapters with the upa or is it In circuit reading/programming ?
Is there anybody having the dump of the program & eeprom of the hc908 on Laguna II ?
I found nothing on it on forum.
I've got a failing dashboard. impossible for me to read the hc908 (coz it's freezed). i've got virgin hc908 but no program .
Should be so glad to share it....
Here you have it,
regards
Puiu
These flash is from Laguna Bencin or Diesel?
BR.
Kusasusa
Doesn't work with your files puiu !
Thx anyway
I think it's coz my hc908 is with 2J74Y mask
I have to manage to get back this F****ing program with the correct mask.
I ll let U know my progress.
I'm a little bit surprised that nobody encountered the same problem with the 2J74Y HC908 on Laguna ?!
Here is from 2J74Y benzin,
fro diesel i dont have....
Puiu
I have a (dashboard laguna 2) failure
I changed the EEPROM memory hc908az60 (2J74Y) with a new one programing by CODECARD.
Now do not have reflash
Now I have INDEX failure of temperature and tachometer
Can please anyone help??????
Can someone please tell me how is the pin out of (laguna ii) dashboard to
check out of car ???????
thanks in advance
you have to change 2j74y for new one,and program both eeprom and flash
br
the chip (MC68HC908AZ60 2J74Y) was new and processor already programmed for laguna dashboard from codecard
OK with this cluster i had two pins with no connection.
Does anyone please help me how reprogramming the
HC908az60 (2J74Y) on board
Thanks in advance
