Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    calin_bm's Avatar
    near civilization
    Default Freelander 2004 mileage correction with upa
    I want to work on this dash ,the dash has inside MC912,i understand that it can be read/write with upa by solder the 4 points behind the dash,can anyone post a picture to see where is the connection and what pins on Upa must be connected?
    Thank you.
    gepakg's Avatar
    Serbia
    this MCU on freelander always secured,must be desoldered to etl,or UPA hc912 adapter,or in circuit with rosfar!
    regards Gepa
    Quote Originally Posted by calin_bm View Post
    Thank you.
    drpeter's Avatar
    The Netherlands
    Thank you.
    Don't have time now to look for UPA pins but here is schematic. I help you later when I have more time
    alldecode's Avatar
    EU, Croatia
    I have same problem and UPA USB not working with this dash, but year is 2001, it is locked too?
  5. The Following User Says Thank You to alldecode For This Useful Post:
    dziongas (13th December, 2017)
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by alldecode View Post
    Yes, I don't think you can do this car with UPA you need to program on a certain frequency, Rosfar R260 is the only way.
    gepakg's Avatar
    Serbia
    also tried with desoldering MCU and read it with UPA hc912 adapter and ETL work fine,but need desoldering..
    regards Gepa
    Quote Originally Posted by drpeter View Post
    calin_bm's Avatar
    near civilization
    yep,desolder,but the real problem is the needles,when you mess with them you will have hard times trying to put them bach in place...
    Moderator
    PremierD's Avatar
    Jun 2009
    Correct me if I'm wrong mate ....2004 in the picture above ...MCU is on the back no need to remove needles ....
  10. #9
    Portugal
    Hi!!!
    And about 912D60 from 2001? UPA, ETL and Rosfar on circuit don?t read.
    BR
    maucontacto
  11. #10
    Portugal
    Quote Originally Posted by maucontacto View Post
    Hi!!!
    BR
    maucontacto
    Solved!!
    Rosfar and direct connection on pins
  12. #11
    Is it possiblle to read this mcu with X-prog m because in the software is not this mask included only under Hc912D60A 112 pins secured?Regards
  13. #12
    Internet zone
    Yes, use Xprog-m no problem.
  14. #13
    justy22's Avatar
    May 2009
    UK
    Is the mcu easy to de solder how many pins does it have, anybody have a pic
  15. #14
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by justy22 View Post
    "Hc912D60A 112 pins secured?Regards "
  16. #15
    Quote Originally Posted by mario313 View Post
    But what adapter to use? In clone box is not bdm adapter which has coaxial cable inside or can use normal cable with same pinout?
