Results 16 to 30 of 31
  1. #16
    Mar 2017
    Portugal
    Quote Originally Posted by Baddog84 View Post
    i use ori tools no crack,...
    I was answering to "MEEF"..from what i can see he was comparing files using 1.61 ECM..
    Sorry for the misunderstood.
  2. #17
    Jun 2023
    here is file with more power
    chks by tool
    thank you, sp how many torque set on this file?
  3. #18
    alonedark's Avatar
    Feb 2017
    450nm is stage 1 bro
  4. The Following User Says Thank You to alonedark For This Useful Post:
    MEEF (17th June, 2023)
  5. #19
    Aug 2014
    1F9DAC and following maps Floating point. gear torque limiters.. stock 420nm.
    stock NM to IQ map is all flattened so axis up to 500 but no real IQ for 500.... gotta fix them
  6. #20
    alonedark's Avatar
    Feb 2017
    You read a lot of, he just try a report
  7. #21
    alonedark's Avatar
    Feb 2017
    Ggbut you could have done it yourself, I'm sure that in a week you'll be able to improve it, I've done it in 15 minutes
  8. #22
    alonedark's Avatar
    Feb 2017
    test the file Ç????? repord please
  9. #23
    Jun 2023
    Guys, need help. When car stay and engine running have 2-3.5l/100km current fuel taking.
    What might be the reason? It's too high.
  10. #24
    Jun 2023
    Quote Originally Posted by alonedark View Post
    Not yet. Will let u know
  11. #25
    Aug 2014
    if car is running but not moving consumption per 100km is infinite.
  12. #26
    Jun 2023
    im sorry the other file i was wrong , check it this file , try and repord free for all the members
    Hi. Thanks for that, but are you sure its done ok and safe?
    quick look on the torque change... its a lot..for example on 800RPM you increased values from 2500 to 10000 . diffrence is 7500, means 400%
  13. #27
    Jun 2023
    Here is the file which im using at the moment.
    Could you guys check and tell what you think. If its ok or dangerous for car etc. (Baddog)
  14. #28
    Jun 2023
    Hi Guys.
    Im still learning.
    This is my file which i modified by myself.
    What you think?
    Any big mistakes?
    Thanks a lot.
  15. #29
    Jun 2023
    hi. thanks for the file, but are you sure its fine?
  16. #30
    Sep 2010
    Quote Originally Posted by MEEF View Post
    Hi Guys.
    Im still learning.
    What you think?
    Any big mistakes?
    Thanks a lot.
    Not bad for start. Lot of maps untouched, lot of limiters not corrected, "percentage mod" ... A good tune needs a lot more effort and work.
  17. The Following 2 Users Say Thank You to proel For This Useful Post:
    MEEF (8th July, 2023)
