Results 1 to 3 of 3
    Apr 2015
    Sweden
    Default RISK! Program keys for AUDI A4/A5/Q5 Encrypted BCM2
    Program keys for AUDI A4/A5/Q5 , 2013-2019, with encrypted BCM2!
    There is no different between add key and AKL, must remove BCM2.
    Tools to use, abrites, xhorse, Autel IM508/608, ACDP and others.
    Using solder free adapters or solder??
    RISKS? As I understood , you are writing back to BCM2 and if connection gets
    bad when writing, you must buy new blank BCM2/no used works! So better solder!
    Is any tool better then others?
    Please share you experience . Regards J
    Aug 2018
    All key lost vvdi 2 + vvdi prog and adapter ,no problem with locked bcm 2. Abrites if you need change Bcm2 , good for synchronization tcu ,ecu and bcm2 .Used bcm 2 works tested Audi A8 4h 2015
  3. The Following 3 Users Say Thank You to Milenium For This Useful Post:
    fred77 (8th January, 2024), vialli (7th January, 2024), wuza (7th January, 2024)
    Sep 2021
    NA
    Tested with soldering (no adapters) on both autel and vvdi2… work okay.
    If you mess it up (power goes off while first reading or similar) you need a new module. I messed up one out of 50+ made.
  5. The Following 3 Users Say Thank You to vov4ik For This Useful Post:
    Milenium (9th January, 2024), Raould (22nd April, 2024), wuza (13th January, 2024)
