Results 1 to 3 of 3
    Jun 2023
    Default MPPS v18 Renault Clio 3 Immo
    I have a Renault Clio mk3 1.2 16v TCe, I dropped it off for a remap and the guy returned it not working. I have been trying many options to fix what he did but no luck whatsoever.
    The issue is that one one of my backup ECU's (SIM32 Siemens (wrong immo, from different Clio)) I have managed to get reflashed so that as soon as it got plugged into the car the immo code writes itself, however that didn't work so I need to manually write it. I have tried a pirate copy of Renault Clip, as well as a pirate copy of RenoLink v1.99 and still no luck.
    I've decided to try MPPS v18 but the Clio 3 isn't on the list, is it at all possible to get the v18 car list (as I saw that my engine is noted there) and manually install it into MPPS?
    Many thanks for any responses.
    Jun 2013
    EU
    Short answer ... no, not possible. Your best option is virgin ecu and recode, or if there is autocoding for it make eeprom autocoding.
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    Ninjor s (20th June, 2023), TequilA011 (20th June, 2023)
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by morgano View Post
    to add,on clio 3 no autocode use clip.
    the lesser you use your brain,
    the louder you use your mouth.
  5. The Following User Says Thank You to Ninjor s For This Useful Post:
    morgano (20th June, 2023)
