Results 1 to 10 of 10
    Default Golf III immo off
    Hello.
    The title said everything.
    Somebody make it for me please.
    I try the immooff file but do not work.
    Golf III
    engine AEK
    bosch 0 261 203 686/687
    VW 037 906 258 AM
    Thnx in advance
    gepakg's Avatar
    Feb 2010
    Serbia
    post immo dump from 68hc05 plcc52
    regards Gepa
    Quote Originally Posted by theodor229 View Post
    Hello.
    I try the im*ooff file but do not work.
    Golf III
    engine AEK
    VW 037 906 258 AM
    Thnx in advance
    Quote Originally Posted by gepakg View Post
    post im*o dump from 68hc05 plcc52
    regards Gepa
    it doesn't have 68hc0. it has 27c512.
    the dump is the 27c512-immo.rar
    rename the file 27c512-immo.bin to open it.
    thnx
    gepakg's Avatar
    Feb 2010
    Serbia
    it is from ecu,i said you to read immo box with 68hc05 inside!
    regards Gepa
    the dump is the 27c512-im*o.rar
    rename the file 27c512-im*o.bin to open it.
    thnx
    it is from ecu,i said you to read im*o box with 68hc05 inside!
    regards Gepa
    I install engine with ecu to another car. that car hasn't immobox. i don't have the immobox from the AEK engine. I have only the ecu with the dump that i post before.
    Any idea?
    thnx
    gepakg's Avatar
    Feb 2010
    Serbia
    hmmm,in that case you must find immo off fro ECU,i dont have...
    regards Gepa
    I install engine with ecu to another car. that car hasn't im*obox. i don't have the im*obox from the AEK engine. I have only the ecu with the dump that i post before.
    Any idea?
    thnx
    hmmm,in that case you must find im*o off fro ECU,i dont have...
    regards Gepa
    yes I know that!!!
    I tryed the second file too but it doesn't work.
    regards
    gepakg's Avatar
    Feb 2010
    Serbia
    by me easy way is to mount immo box and wire 6 pins...
    regards Gepa
    yes I know that!!!
    regards
    Member elasrisimo's Avatar
    Mar 2010
    france
    [QUOTE=elasrisimo;507961]
    Peugeot 307 Complete Wiring Diagrams
    Jan 2011
    Bonjour Je faais une apprentissage de peugeot 307 quant on change la betterie il ne demarre plus il faut entrer une nouvelle code, quelqu'un peut m'aider merci
