    Poland KRK
    Default programmer for hc05l28
    I need schematic diagram of programmer for this procesor.
    Rito's Avatar
    This is for upa.
    I dont know what programmer do you have..
    Poland KRK
    This is universal programmer, i need only for hc05l28
    Land of Rocks
    Quote Originally Posted by RW74 View Post
    Download the datasheet and make it yourself with max232 the serial interface and then write the sw . You will have your own programmer home made if those universal arent good.
    siti's Avatar
    RO-ALBA
    hi try this
    Rtronics's Avatar
    Australia
    hi, can someone give me schema to connect smok multiprog to this hc05l28 56 pin. they have schema foe square 52 pin not long rectangle 56 pin.
    I have upa connection which I did before but for some reason having trouble today. I want to try smok. anyone can modify my pic for smok connection.
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
