Can you then advise me why the ecu "doesn't live" after uploading (either via k-line or via the flash programmer after desoldering)? However, this map is original from the given ecu.
hello did you write until the end and with what tools because your checksum is good but manage to read with mpps and at the time of writing it no longer works and no way to read after the computer but the car has started all the same
Initial reading was done via FGTech Galletto 4. Subsequently, after turning off the EGR, recording failed at 90%. Next, I desoldering the flash and loaded the SW there via an external flash programmer (the ecu didn't work / didn't communicate). Then, after desoldering the flash, I uploaded the original file there again, again with no response. I would like to save the map because the car was perfectly tuned with it (perfect consumption and performance). At the moment, when I put another ECU there and upload the serial map for the given engine, the engine pulls like HTP and the consumption at idle is 2.5l/h (which leads me to think that the engine has been modified more deeply (different injections and the like...) )
Why does every map (whether original or downloaded from the Internet) for 038906019PE give me this message when opened in VAGEDC Suite? ..... If I upload any map for another EDC15P+ to the ecu, the ecu works. As soon as I upload the map there (whether original or downloaded from the Internet) for 019PE ecu does not live.
At the moment, I made an "adapter" for quick swapping between the ECU and the Flash Programmer, so if you have any ideas what to try or how to upload the map for 019PE to my ECU, it can be quickly tried without desoldering and soldering
Do you have working backup of the ecu when it started the car last time?
Which engine code is the alhambra?
None of the alhambra file i have match your ecu numbers
Try this AJM dump.
Have some Dumps from 115hp alhambra.
In my very first message above, there is the original file from the time when it was still starting.... after uploading it to the ecu, it neither communicates nor starting engine.
The engine code is BVK, the car's year of manufacture is 2008, it's the last revision EDC15P+, it even has two "plus" in the name, it's EDC15P++
I'm starting to think if they didn't try to add encryption like in EDC16, which was the next generation
When I upload the file for Alhambra 115hp, the engine does start but has absolutely no traction and the consumption at idle is 2.5l/h
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
@kiszka modfile is in first post
you have socket for put and remove for 29fxxx too ,
