if interested contact in pm
Can someone help me clone MED17.5.20 for VW Golf 5 1.4TFSI?
Ori ecu info :
ECU NR :
0261201788
03C906022J
Engine code: CAXA
HW:H05
MED17.5.20
Donor ecu info :
Donor ECU is from a Seat Leon with different engine code CAXC but it is MED17.5.20 and was in the compatibility list at BOSCH
ECU NR :
0261S04396
03C906022AQ
Engine code: CAXC
HW:H10
MED17.5.20
Donor ecu info
VIN="VSSZZZ1PZBR002192"
CS="AE AE 3F 7B 5D 5C 00"
MAC="5E 77 14 87"
Config="37 E5 54"
PIN="07906"
Immo Type="IMMO 4"
Ori ecu info
VIN="WVWZZZ1KZ8W569816"
IMMO ID="VWX7Z0H03NL8CR"
CS="80 FB 59 63 01 F6 00"
MAC="E6 4C A8 39"
Config="37 E5 54"
PIN="02386"
Immo Type="IMMO 4"
here is your file test please and Report
Please Press Thanks Button and Reput if i helped !
madjqker (4th August, 2023)
I've transferred the IMMO files as you asked, test and feedback plz.
PS: The 2nd ECU if you have is from Skoda
Thanks for your help guys. I will give a feedback tomorrow once I test it.
Hayssam1 (4th August, 2023)
i've tested and it doesn't work. The solutions you both posted are the same.
Any advice would help.
madjqker (7th August, 2023)
Thanks Hayssam1.
Solved with immo off.
Hayssam1 (7th August, 2023)
