Results 1 to 9 of 9
    Nov 2013
    Default VW GOLF 5 MED17.5.20 CLONE-Transfer immo
    Can someone help me clone MED17.5.20 for VW Golf 5 1.4TFSI?
    Ori ecu info :
    ECU NR :
    0261201788
    03C906022J
    Engine code: CAXA
    HW:H05
    MED17.5.20
    Donor ecu info :
    Donor ECU is from a Seat Leon with different engine code CAXC but it is MED17.5.20 and was in the compatibility list at BOSCH
    ECU NR :
    0261S04396
    03C906022AQ
    Engine code: CAXC
    HW:H10
    MED17.5.20
    Feb 2016
    United Kingdom
    if interested contact in pm
    Hayssam1's Avatar
    Germany
    Quote Originally Posted by madjqker View Post
    Ori ecu info :
    ECU NR :
    0261201788
    03C906022J
    Engine code: CAXA
    HW:H05
    MED17.5.20
    Donor ecu info :
    ECU NR :
    0261S04396
    03C906022AQ
    Engine code: CAXC
    HW:H10
    MED17.5.20
    Donor ecu info
    VIN="VSSZZZ1PZBR002192"
    CS="AE AE 3F 7B 5D 5C 00"
    MAC="5E 77 14 87"
    Config="37 E5 54"
    PIN="07906"
    Immo Type="IMMO 4"
    Ori ecu info
    VIN="WVWZZZ1KZ8W569816"
    IMMO ID="VWX7Z0H03NL8CR"
    CS="80 FB 59 63 01 F6 00"
    MAC="E6 4C A8 39"
    Config="37 E5 54"
    PIN="02386"
    Immo Type="IMMO 4"
    here is your file test please and Report
    Please Press Thanks Button and Reput if i helped !
  4. The Following User Says Thank You to Hayssam1 For This Useful Post:
    madjqker (4th August, 2023)
    Feb 2016
    Bulgaria
    I've transferred the IMMO files as you asked, test and feedback plz.
    PS: The 2nd ECU if you have is from Skoda
  6. The Following User Says Thank You to albizkit For This Useful Post:
    Nov 2013
    Thanks for your help guys. I will give a feedback tomorrow once I test it.
  8. The Following User Says Thank You to madjqker For This Useful Post:
    Hayssam1 (4th August, 2023)
  9. #6
    Nov 2013
    i've tested and it doesn't work. The solutions you both posted are the same.
    Any advice would help.
  10. #7
    Hayssam1's Avatar
    Germany
    test this one and reports
  11. The Following User Says Thank You to Hayssam1 For This Useful Post:
    madjqker (7th August, 2023)
  12. #8
    Hayssam1's Avatar
    Germany
    if you want here also immo off
    immo off write all
    eeprom and flash
  13. The Following User Says Thank You to Hayssam1 For This Useful Post:
  14. #9
    Nov 2013
    Thanks Hayssam1.
    Solved with immo off.
  15. The Following User Says Thank You to madjqker For This Useful Post:
    Hayssam1 (7th August, 2023)
