you need to make a configuration, preferably diagbox
HI,
I've made IMMO OFF on BSI to put any BSI and start the car, but with original BSI it does not roll up/down front windows.
With donor BSI, windows works, but the car does not lock/unlock anymore.
What is wrong ? ORIGINAL BSI is from 2001, donor is from 2003, same eeprom from what I have read.
I've put another BSI from 2005 and same problem, also AC does not work with any of BSI.
but ecu is virginised, I can use any BSI. Do I need pin code ? Pin code is stored in BSI ?
BSI will need to be configured with Diagbox, especially if its virginised, BSI will need to know what is installed on the car before those functions work.
you need a pin code , stored in the bsi
In settings there might be “electric windows on or off”
must be immo off in ecu
pawl (18th August, 2023)
I"ve done immo off in ecu already. But lexia does not connect to engine anymore, stupid .
Only way to read pin from BSI is to work on "bench" right ? I can start the car with any BSI.
