try this and give answer.
probably car will start, but diag. tool will show you
"eeprom error". check
regards
segal75
regards
segal75
This file is 100% okay and will work
ECU Commander Studio?
Hand in Hand to Protect our Efforts - Stop Hunting Our Work
>>>>>EBAY SELLERS<<<<<
I'm not Sharing Passwords!
Do not argue with an idiot. He will drag you down to his level and beat you with experience
yes
It's correct
>>>>>EBAY SELLERS<<<<<
i can also tell at this should work
Great, thanks.
You are right it work!!!!!!!!!!!!!!!!
Well thanks a lot friends and sorry to ask you so much. After test it several times all error has gone and it is working quite good. Thanks a lot!!!!!!
Hi again friends. Sorry to bother you so much but I have a doubt. I have using the car almost a week and I admit that is running normally. To be safe I scanned it again with VagCom and this is what I got:
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55 ,56,57,75,76
Address 01 -------------------------------------------------------
Controller: 06A 906 018 JJ
Component: 2.0L R4/2V MOTR HS V01
Coding: 00031
Shop #: WSC 00066
1 Faults Found:
16989 - Internal Control Module: ROM Error
P0605 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01317
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 826 A
Component: KOMBI+WEGFAHRS. RB8 V11
Coding: 05102
Shop #: WSC 00000
WVWZZZ1JZ2W420330 VWZ6Z0A4031013
1 Fault Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
No fault code found.
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1C Komfortger?t HLO 0003
Coding: 00259
Shop #: WSC 01317
End -------------------------------------------------------
Sorry about the old VagCom but is what I have right now. I know you tell me about the ROM error, but do you think that the ABS module and Cluster communication issues, could be related to the im*o disable?
The dash is working normal and I notice I got a little more travel in brake pedal, but in general are working good.
Some tips and advice will be great. Anyway the car is running good but I will to know a little more info about that errors, the immo disable can generate that issues?
Thanks a lot again for your help.
i want to kill my immo 3 on a golf 2002
