Results 1 to 11 of 11
    Nov 2018
    Default 2016 Kubota M6-131 cluster hours correction
    2016 Kubota M6-131 cluster with 93C66. It has 6,100 Hours and has to be 3,100 H.
    Apr 2021
    Here is your file
  3. The Following User Says Thank You to MrHenrick For This Useful Post:
    Dashboard (8th September, 2023)
    clusters's Avatar
    Mar 2015
    Canada
    Here, with no password
  5. The Following User Says Thank You to clusters For This Useful Post:
  6. #4
    Nov 2018
    Thanks for both of you, but unfortunately the file is not good the cluster shows E-Mem instead of correct odometer. Any idea?
    clusters's Avatar
    Mar 2015
    Canada
    Check eeprom orientation and soldering.
  8. #6
    Nov 2018
    Maybe there is a checksum problem? Orientation and soldering of eeprom is good. With original file shows properly the hours. Any help would be appreciated.
  9. #7
    Oct 2010
    im having the same E MEM message when i adjust useing orange calcs , did u sort it out
  10. #8
    Dec 2010
    vietnam
    Quote Originally Posted by Dashboard View Post
    cluster do not have cs! algo yaraki! file form Cluster work ok! i have more 300pcs maken!
  11. #9
    Aug 2020
    Hi, I got the same problem with error memory, kubota m40xx 93c66, I found it: 1st and 2nd lines in eeprom must correlate with 8th line. Can somebody calculate it? editing only 2 first lines change hours but w/o editing 8th line still will be error
  12. #10
    Apr 2018
    EU
    Quote Originally Posted by karolturbo View Post
    Posting your file could help.
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
  13. #11
    Aug 2020
    Thanks for answer, probably I solved that problem, on bench all is ok, tomorrow I'll test it in tactor. If somebody got this problem, try to put it in 8th line 00 00 14 00 00 00 14 00 00 00 00 00 00 00 01 00
