Here is your file
Here is your file
Dashboard (8th September, 2023)
Here, with no password
Please DO NOT PM me asking for help.
Post in the forum, that is what it is here for.
Thanks for both of you, but unfortunately the file is not good the cluster shows E-Mem instead of correct odometer. Any idea?
Check eeprom orientation and soldering.
Maybe there is a checksum problem? Orientation and soldering of eeprom is good. With original file shows properly the hours. Any help would be appreciated.
im having the same E MEM message when i adjust useing orange calcs , did u sort it out
Hi, I got the same problem with error memory, kubota m40xx 93c66, I found it: 1st and 2nd lines in eeprom must correlate with 8th line. Can somebody calculate it? editing only 2 first lines change hours but w/o editing 8th line still will be error
Thanks for answer, probably I solved that problem, on bench all is ok, tomorrow I'll test it in tactor. If somebody got this problem, try to put it in 8th line 00 00 14 00 00 00 14 00 00 00 00 00 00 00 01 00
