    Aug 2022
    Scotland
    Question Need key code for nissan qashqai uk
    hi , i tried to buy the key code for a nissan qashqai 2008 UK BUT the supplier been unable to get it .
    i have the vin and reg no : NV08KFR
    VIN : SJNFCAJ10U1246209
    Dec 2010
    Nottingham
    Lishi NSN14 pick and decoder
    lishi NSN14 direct reader
    both will allow you to get the key cuts or most suppliers can get the code like 3d group etc
    personally i pick and decode the lock which is quick and acurate
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    super jumbe (18th September, 2023)
    Aug 2022
    Scotland
    Quote Originally Posted by rapidlocksmiths View Post
    i have ordered from 3d BUT the supplier been unable to get it .
    lishi ...it-s 2 missing wafers from the door to ignition as the key its a semi-smart ... and the lishi what i got it-s v2 ...
    Dec 2010
    Nottingham
    you can use software like instacode to find the missing 2 cuts , it will be 1 of 4 keys as only 4 possible combinations in 1st 2 positions 1-2; 2-1; 2-3; 3-2.
    though as semi smart key i suspect you mean the intelligent key with turn knob on ignition , if so you will find the ignition does not contain all 10 cuts in fact often have just 1 wafer in them , i suspect you will be able to do this without finding the missing cuts with the pin code .
    once you enter the pin the steering lock will release you will be able to turn on the ignition to program the transponder , this has been covered on dk many times in past , all you had to do was use the search function
  6. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    AAKEYS (21st September, 2023), Weasel3 (19th September, 2023)
    Aug 2022
    Scotland
    i done thank you 1st time decode with lishi and cut 1-2 and good to go !!!
  8. #6
    Dec 2012
    EU
    I can get key cut for nissans ..
    Sent from my SM-G965F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
