    Feb 2018
    Default Renault master, EDC16 0281013364 EEPROM ERROR P062F
    Hi all.
    Have a renault master horse box with a P062F. no other dtc's at the moment. Vehile is starting and running fine with no issues. Just have the engine management light on and this dtc.
    Can someone possibly check the eeprom data for errors for me.
    Especially the checksums i possible.
    I have attached the original EEprom data.
    Thanks in advance.
    tinchocbr's Avatar
    In my house
    Upload mpc, and i try erase code faut.
    Feb 2018
    Quote Originally Posted by tinchocbr View Post
    sorry for the delay. I went through a few programmer's before I could read the flash.
    What I am finding weird is the ecu set up.
    I have an MPC562
    M58BW016 FLASH
    95320 EEPROM
    But ktag etc list's a 95640 eeprom for this ecu.
    Please check the file and let me know if it looks correct, or as you say, the dtc can be removed.
    Best regards
    Mike
    Jul 2013
    Here you go eeprom cs repair
    Feb 2018
    Quote Originally Posted by Nikola1309 View Post
    Thank you very much, worked perfectly. All faults now cleared.
    Feb 2018
    Hi, Please can you check the file again.
    The van had an issue with fuel hand primer pump and the fuel ran back to the tank, when I tried the ecu file all faults were clear, However I couldn't get it started. The van was starting and running before but with the eeprom fault.
    I have had time now to test the vehicle, I used another ecu and the vehicle starts.
    There must be something still wrong with the file.
    Thanks in advance.
