Results 1 to 15 of 16
    Default GOLF 6 odometer correction
    hello
    I have done a golf 6 by diag with dp3.. do this car have any stored mileage memory's?
    Regards speedofix
    z786's Avatar
    10 Steps Ahead of You
    Engine ecu, edc 17 if it was a diesel, not sure if any tool can do that, ABRITES VAG Commander mite be able 2 im nt sure
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Sure about this? someone tell me that mileage only stored in gateway in VAG cars with edc17?
    z786's Avatar
    iv neva done a golf 6, but i was told by another tech that it is stored in edc 17, im sure some of our members here will shed light on it.
    have you changed it in the gateway??
    greece
    if they have automatik transmision also thear i transmision ecu
    Yes only DSG automatic girbox have memory for milage!
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by Speedofix View Post
    Yes EDC15 EDC16 EDC17 in ecu
    Starting years of EDC16 also automatic gearbox
    For golf6 i m not sure.....
    HELLO
    YOU CAN CHANGE MILEAGE ON GOLF 6 BUT
    ONLY THE LAST MILEAGE
    EX: 65435km and it become only 65000 km
    even you make it 25000 km
    mastaflex's Avatar
    Jan 2009
    FR47310
    no tools for EDC17 at the moment but mileage is stored in ECU and GEARBOX if it's DSG
    Golf6 Jetta6 gasoline stored in cluster and gateway and DSG if diesel in EDC17 too.
    mastaflex's Avatar
    Jan 2009
    FR47310
    yes i forgot gateway also
    z786's Avatar
    this thread is OLD
    what is the point of repeatin things again and again?
  13. #13
    Member topepi's Avatar
    EU
    Hello friend
    In all edc17 VAG have stored mileage but if you change in dash mileage after are changed automatic in edc17 this is full CAN ,no need to change in ecu.
    If you want check it go with VCDS in:
    01-engine
    08-Meas blocks
    go to search in Group 90 to 109 i forget where ,
    and you see value Mileage in edc17 is sam dash .
    For DSG you can change mileage with DP3 option package.
    You no have DP3 sam me you can reset it to 0 with VCDS
    go to 02-Auto Trans
    search value odometer in Meas.Blocks-08 Group 001 to 120 i forget where.
    after if you have number group go to Adaptation and reset it to 0 or test change only value if you want.
    Before change value or other ,please Check ,i forget because i no have VAG edc17 now for check number group or other.
    Good luck
  14. #14
    K.Kambelovac Croatia
    Topepi
    Useful information.Thenks
  15. #15
    Rito's Avatar
    How you change in Gateway??DP3 do it OBD??
    I think gateway can clear by error cleaner.....
    Why you say not need to do EDC 17??
    In golf5 is same have in Dash,EDC16 and DSG is automatic..
    So we need to do all....
    Can you explain better'?
