Results 1 to 3 of 3
    May 2018
    West Yorkshire
    Question 2013 Honda civic R18Z4 p0420
    Good Evening,
    Got stuck with one i'm not used to, wonder if anyone can give us a hand.
    Long story short, partners dads civic burning oil, put a low millage replacement engine in, all is good except p0420 cat bellow efficiency.
    passes emissions but obviously the cat is damaged to some degree.
    I do lots of immo work but usually obd or basic bench. never had to touch the ecu flash side of things, and thought best let someone who does this a bit more often handle it, so paid someone to re-flash and they said "turned off the lambdas". obviously the fault returned, as far as i was aware there's more to it than that and the p0420 needs identifying in the flash file and removing so it just cant appear.
    I'm tempted to purchase a PCM-Flash kit and read it myself but I wouldn't know where to begin looking to remove that fault code. Would anyone on here be able to assist or have a flash file for that engine with that fault code removed, ready to write in?
    Yes i'm trying to do this on the cheap, usually not how I like to do things, but ended up roped into family stuff....
    Also open to recommendations to tools for the job if there is a better alternative.
    Sep 2022
    SriLanka
    hi.
    what ECU ? if its a keihin Ecu read it wih pcmflash ,,, and post here...
    May 2018
    West Yorkshire
    Quote Originally Posted by Duwagemadusanka View Post
    hi.
    Thank-you i will order the kit and post the file.
    Cheers,
    <-- Please thank if i can help you
