Dump vdo 3B0920847E - can not login to Odometer
Results 1 to 7 of 7
    Jan 2010
    Mosc
    Default Dump vdo 3B0920847E - can not login to Odometer
    Hello, I have a problem - I can not log on to the odometer to encode the new key. Entered the correct pin code. Always pops up when entering the code word FAIL on the odometer. Please study my DUMP, and instructions which can cause...
    DUMP is here :
    Passat forum
    I use vcds 812.4 .
    Passat b5 lift, im*o3,
    umoussa's Avatar
    Jul 2009
    Universe
    Hi M8,
    Here you go a working dump
    Contact me on PM for PAssword and code
    ECU Commander Studio?
    Hand in Hand to Protect our Efforts - Stop Hunting Our Work
    >>>>>EBAY SELLERS<<<<<
    I'm not Sharing Passwords!
    Do not argue with an idiot. He will drag you down to his level and beat you with experience
    Poland
    hjulet - your link not work , use rapid share or other server
    Jan 2010
    Mosc
    Poland
    You pin is ok
    See : http://wiki.ross-tech.com/wiki/index...ching_(Cluster)
  6. The Following User Says Thank You to mes_cal For This Useful Post:
    igoro (29th November, 2016)
  7. #6
    Jan 2010
    Mosc
    Everything I did score a good procedure. and each time the counter is FAIL
  8. #7
    umoussa's Avatar
    Jul 2009
    Universe
    Check your PM Please
    Thank you
    >>>>>EBAY SELLERS<<<<<
