Ah, does anyone understand???
Good afternoon, can you help me with my file? I had a 1749va turbo and I put a hybridized 1756, it turns out that the turbo takes a while to gain pressure, and at high speeds it sometimes overboosts, I tried adjusting the n75 map and the target boost improved, but if you pressed the throttle to maximum pressure near 2500rpm /3000rpm there is overboost.. here is the attached file. Thanks, good curves
Better begin to post in english if u hope for someone to help u.
If u can log, i might be able to help u with that file.
i've sent u pm with my direct contact.
EricSaliko (25th October, 2023)
Can anyone here help me please?
13 Posts, you come with this problem and want's free solution?
Well you don´t need only adjust N75, you need adjust EOI correctly (attention i don´t saw your file but i think is the problem because when install hybrid turbo it's normal makes overboost with incorrect EOI....)
I already gives you the solution soo good luck and report...
EricSaliko (27th October, 2023)
infelizmente só estou procurando ajuda.. muito obrigado pela dica amigo, vou focar mais aí
