Results 1 to 7 of 7
    Sep 2023
    Default 1.9 pd 130cv I need help adjusting 1756
    Good afternoon, can you help me with my file? I had a 1749va turbo and I put a hybridized 1756, it turns out that the turbo takes a while to gain pressure, and at high speeds it sometimes overboosts, I tried adjusting the n75 map and the target boost improved, but if you pressed the throttle to maximum pressure near 2500rpm /3000rpm there is overboost.. here is the attached file. Thanks, good curves
    Sep 2023
    Ah, does anyone understand???
    Mar 2017
    Portugal
    Better begin to post in english if u hope for someone to help u.
    If u can log, i might be able to help u with that file.
    i've sent u pm with my direct contact.
  4. The Following User Says Thank You to marko6jpt For This Useful Post:
    EricSaliko (25th October, 2023)
    Sep 2023
    Can anyone here help me please?
  6. #5
    Jan 2011
    13 Posts, you come with this problem and want's free solution?
    Well you don´t need only adjust N75, you need adjust EOI correctly (attention i don´t saw your file but i think is the problem because when install hybrid turbo it's normal makes overboost with incorrect EOI....)
    I already gives you the solution soo good luck and report...
  7. The Following User Says Thank You to jonas000 For This Useful Post:
    EricSaliko (27th October, 2023)
  8. #6
    Sep 2023
    infelizmente só estou procurando ajuda.. muito obrigado pela dica amigo, vou focar mais aí
  9. #7
    Jan 2011
    Quote Originally Posted by EricSaliko View Post
    i don´t see file but on name say "stage2" if you can do stage2 can adjust EOI...
