Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 52
  1. #31
    Sweden
    here is eeprom dump from 24c32, it have about 120 877km now and i like to have around 178 000km
  2. #32
    Quote Originally Posted by gizmo666 View Post
    if mask is 3272 i can edit for you
  3. #33
    Sweden
    it was cdc3217g...
  4. #34
    DK Veteran deffc0n's Avatar
    UK/POLAND
    Try this and send info
  5. #35
    Sweden
    i will try this later today and let you know how it goes
  6. #36
    UK
    it was cdc3217g...
    Your gonna need r250 interface or similar to program cdc3217 mate.
  7. #37
    Jun 2009
    hi gizmo, can you tel us if that works or no??? i mean deffcon dump, work's?
  8. #38
    Sweden
    sorry ,it isnt work but here is dump what works 100% right maybe it helps someone...
  9. #39
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Quote Originally Posted by zanovo View Post
    I upload pictures, let somebody show you connections.
    I prefer to desolder the chip.
    And if somebody has last updated Elsa... please upload connector pinouts for this dash (32 pins)!
    for this EEPROM 24c32 , can i just take it out and put it on a suitable serial programmer and then writing the new modified dump file on it then soldering it back to its place on the PB ??? will this be enough to get the new desired mielage reading ? or there is another programming part on the NEC processor?? plz note that am not using OBD connector,but i am using OBP method for those micro wires such as 24Cxx,93cxx,25cxx ..etc ,and that was working for all previous cars that i have adjusted before .. is there any new changes here for vag cars over 2008 models that i should consider... also plz if you can tell me about the code calculations method and the codes addresses, are they still the same as in 2007 < models or there are changes have been done ,plz explain this as much as u can and if there are some supported pics ,then that would be a great favor, thanx for your time and hav a great day.
  10. #40
    Sweden
    i have done skoda octavia 2008 succesfully sometime ago now, you only need lift xtal pin and prosessor pins lmarked in picture + connect green wire to pcb too
    I have try this to to diffrent skoda octavia 2008 speedometer and it work for me both times...
  11. #41
    gizmo666 , can u plz tell me which pogramming tool did u use (vag-prog) or R250..etc?? also please can u post again the wiring connection pic which show those pins that shoud be lifted of the processor, and what do u mean by connecting the green wire to the pcb, which green wire and which tool uses that method??
    tanx in advance ...
  12. #42
    Sweden
    i use r250 programmer to do the job,wiring picture is in attachment.
    I hope this helps
  13. #43
    poland
    hello,
    i have skoda octavia 2007 dashboard with Micronas 3272 and 24c32, i have R250, I connected as Golf 5 but not work.
    I use Xprog-M but don't work too. I lift two pins and xtal. Anybody help me? What is wrong? Mabey somebody can change mileage only in 24c32, I can post dump.
  14. #44
    Sweden
    i have done several skoda 2007 models now without any problems..
    Just remember lift pins from ic and xtal pin, also remember connect green wire right place, check my posted picture.
  15. #45
    Holtek's Avatar
    Scoda Octavia 1,9 TDI 2009. Processr: NEC uPD70F3424GJ(A)
    What programmers can change the mileage? Not via OBD! Is there any simple method?
