Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Mondeo 2010
    May 2012
    Uk
    Default Mondeo 2010
    Hi all
    I programmed a Mondeo 2010 today with dp3 and accidentally pressed change units 'from miles to km'. the dash then read in km.
    Tried to change back but with no success. Took bat off then tried again once reconnected but still no joy.
    Anyone had similar problem?
    Cheers
    ALEXEI's Avatar
    Apr 2010
    drive the car more than 50km and try to modify again
    May 2012
    Uk
    Tried it mate. Still no joy.
    Would anyone no how to modify dump if I posted 9s12 data?
    May 2010
    send dump to elprosys and let them change it back for you.
    May 2012
    Uk
    I'm thinking it must be a byte that's changed so I intend to take out the next one I get read and save data with programmer direct. Then change units but not mileage with dp3. Then re read with programmer direct and see what's changed.
    Does that make sense or can someone with knowledge tell me I'm a ****!
    Regards
    Dec 2009
    Prussia
    Quote Originally Posted by lama23 View Post
    Regards
    You where doing it diagnostically?
    Jul 2010
    Ireland
    Disconnect the battery for 20 mins.
    Connect your D3 cable and do it again this time selecting the change option "1" again to change back to miles.
    Pager.
    May 2012
    Uk
    Tried disconnecting the battery. Didn't work.
    May 2012
    Uk
    Yes I was doing it diag and now when I try to change units back to miles it says it's done it but Kms still show and when I go into settings on car it will not change.
    Does the reading of one direct make sense?
    Dec 2009
    Prussia
    I have had this same thing.
    You must change the settings on the dp3
    then do it again, try a few times
  11. #11
    May 2012
    Uk
    I have tried many times but will have another go Monday.If all fails I'll have a go reading one direct then change units with dp3 diag then read again and see where it's changed.
    Cheers
  12. #12
    Dec 2009
    Think you missed the point go into your dp3 menu and change units from km to miles then do job again should work other than that nothing will help you
  13. #13
    May 2012
    Uk
    I'll give it a go.
  14. #14
    Dec 2009
    Prussia
    Quote Originally Posted by diagtech View Post
    You can say that again!
  15. #15
    May 2010
    i dont understand, now its 5 day ago and still trying to fix it.
    if you send the dump to elprosys they know exacly what byte the machine change so they can change it back manually for you. maybe problem was solved in 1 or 2 days.
    but hats mine way of thinking.
