Hello!
I need to add mileage in Skoda Octavia New 2009 (NEC + 24C32 in dashboard).
Is it possible to do by correcting only 24С32 dump, without touching the NEC ?
Somebody tell me that it is necessary to correct 24C32 dump in two places - is it true?
Thanks for any help!
I have found a post about it! Your soft is very useful!
But a few questions else:
1 Can I use tacho Universal + CAN dongle or VAG K+CAN commander to change mileage after entering service mode?
2 Can I simultaneously change dump for entering s.m. and change mileage manually ?
Thanks!
i think the answer for both of them wud be NO
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
It`s sad!
But what device I need to do the second part of this job through OBD-II ?
And is it possible to do this job manually.....may be so:
1 Use 24C32 in DIP8..... conect it through panel or clip to board.
2 Put NEC in s. m.,connecting the dashboard to 12V on a table.
3 Take 24C32 out ...... change mileage, put it back (Power is on)
4 Reset dashboard.
You can try to change the 24C32 to go into service mode and read whole dump with vag+k commander, and then adjust mileage and write all back. Don't know if it works but you can try. If you post 24C32 dump here I will change the dump for you. I use VAG DASH PROG for this. You don't have to remove 24c32 just solder 4 wires on back of board, see forum passat 2008, golf 6, PassatCC for pictures.
Look here:
http://www.digital-kaos.co.uk/forums...m-tools-68204/
Skoda, Golf6, Passat CC Ibiza Leon etc... all the same
honda city 2004 how we do mileage correction with tacho universal
hi
r250 its tool good
Skoda Octavia New 2009 (NEC + 24C32 R250 not cover this dash use vagprog
hi Skoda Octavia NEW 2008
km problem dash 24c32+cdc3297g
rosfar R250
UNABLE TO ESTABİLİSH A lNK WİTH THE PROCESSOR
rosfar R250
