Some more info for those interested:
Checksums, the quick and dirty way..
For boot loader, there is an address just after the start of the code
at 200h which show where the BOOT section end, this address is in word
format. Highlight the BOOT section up to the word address, calculate
the CRC16 and you will see it match the checksum directly at the end
of that section.
For the CODE section you do as follows, go to address 3DBEh, here you
will find a address in the start of the CODE section, goes to this
address and again here you will find the END OF CODE address,
highlight the code from 10000h up to this address and calculate the
CRC16 and you will see the check sum match directly after the code end
word.
I have not successfully decode the DATA section, for some or other reason this does not work for the data, any ideas?
